Old 06-06-2007, 05:52   #1 (permalink)
Member: 403881
Thanks Meter: 80
Network Experts
I have 4 Nos of 3310 set in which full network comes when switch on the phone and network goes within 30sec-1min i already changed fowings
1.PA
2.Antina Switch
3.COBBA.
But still no result during searching it says NO NETWORK ACCESS , All experts are kindly requested to suggest solution.
REGARDS,
Old 06-06-2007, 08:56   #2 (permalink)
tabuki's Avatar
Member: 455665
Thanks Meter: 36
1.PA
2.Antina Switch
3.COBBA.
REGARDS,
hi! friend try this-remove PA and antenna switch and make jumper,follow greenline,sorry about my drawing
The Following User Says Thank You to tabuki For This Useful Post:
Old 06-06-2007, 11:35   #3 (permalink)
meo786pk's Avatar
Member: 465162
Thanks Meter: 683
first it flash it and write good PM
Old 06-06-2007, 11:52   #4 (permalink)
meo786pk's Avatar
Member: 465162
Thanks Meter: 683
Old 06-06-2007, 13:34   #5 (permalink)
jothi737's Avatar
Member: 369539
Sonork: 1584109
Thanks Meter: 32
hello meo786 this is dct 3 how to write pm ?
MR sarojrkl this is ccont problem change or reball ur problem solve
Old 06-08-2007, 06:40   #6 (permalink)
Member: 403881
Thanks Meter: 80
thanks dear for your suggestion i will do what u said and post result.
Old 06-08-2007, 07:47   #7 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
Smile
hi br full signal problem solution i hope it wil b very help full br
..::Mr Fone::..
The Following 2 Users Say Thank You to ..::Mr_Fone::.. For This Useful Post:
Old 06-08-2007, 08:30   #8 (permalink)
lahoot's Avatar
Member: 229987
Sonork: 100.1602834
Thanks Meter: 193
i think ur set is water damage
first of all
Check + ways, if ok
Reheat of Rebal to Coba
and Rebuild iMEI
Ui Setting
will b ok
The Following User Says Thank You to lahoot For This Useful Post:
Old 12-23-2007, 16:54   #9 (permalink)
Member: 315775
Thanks Meter: 9
i have nokia 3310, when i switch on, the network comes about 3 second the network drop.when i search network manually it appear maxis , digi and celcom but when i select one of them it say no acces. what should i change.
Old 12-23-2007, 17:53   #10 (permalink)
Member: 465901
Thanks Meter: 45
first of all check the +ve supply on the P.A ( to amplify signal we have to give dierect supply to signal ). if this track is ok then change the P.A and short the antenna switch. problem will be solved
Good Luck
The Following User Says Thank You to ZENITHMOBILE For This Useful Post:
Old 12-23-2007, 18:45   #11 (permalink)
Member: 246407
Thanks Meter: 3
iam totally agree with zenithmobile
Old 12-24-2007, 06:22   #12 (permalink)
Member: 315775
Thanks Meter: 9
thanks bro ... i will try it
Old 12-24-2007, 13:29   #13 (permalink)
tdnetwork's Avatar
Member: 286557
Thanks Meter: 21
Hi mate i have nokia 7360 it has network but flontuate wath do i do ?
Old 12-24-2007, 17:25   #14 (permalink)
Member: 248245
Thanks Meter: 85
1.PA
2.Antina Switch
3.COBBA.
REGARDS,
IF SIGNAL GOES AFTER 30-40 SECOND YOU CHANGE COBBA AND 13 MHZ CRYSTAL.
Old 05-24-2008, 16:27   #15 (permalink)
Member: 476023
Thanks Meter: 4
thanks it work.......................!
HTC Repair Experts... Bluetooth and Network Schematic Pls.. LoveLess HTC & PDA WM( With Touchscreen) 1 06-16-2009 17:53
iPhone 2G issues - no network - need expert advice techie786 iPhone 2 / iPhone 3G / iPhone 3GS 8 08-20-2008 04:59
6101b Ask the experts to engage the image I want to modify network LIVE_GSM Nokia Hardware & Hardware Repair 0 08-21-2007 23:21
3120 Network Problem- Experts Only serchingeye Nokia Hardware & Hardware Repair 6 02-02-2007 13:38
Page generated in 0.31627 seconds with 10 queries
