05-21-2011, 16:06 | #1 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Green Forest
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | new nokia 1202-3/1661 keypad solution in keypad, back / 3 / 6 and ** key not working. i change keypad ic but problem not solved. then i re-boll UPP. still same problem. finally i change UPP but bad luck problem not solved. then i check the keypad track and i found my phone fault. and i use this method to repair this line. now my phone is ok. keypad have 2 way line 1-out line. see pic in out line menu/left/*/0/** same line up/4/5/6/7 same line back/send/down/8 same line right/1/2/3/9 same line if outer line is damages some keypad not work. example if phone */0/** key not work but menu and left work. then try this pic 2-middle line see pic in middle line up/menu/down/9 same line left/right/send/7 same line back/3/6/** same line 1/4/* same line 2/5/8/0 same line if phone middle line is damages then try this example this middle line work in back/3/6/** key you can make this mostly this problem found in water damages phones. BR net.tarik |
