View Poll Results: Hows the thread??like or not | |||
about basic | 2 | 66.67% | |
about concept and logic | 2 | 66.67% | |
About parts | 1 | 33.33% | |
u r upgrading or not? | 2 | 66.67% | |
Multiple Choice Poll. Voters: 3. You may not vote on this poll |
10-30-2006, 11:25 | #1 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 205738 Status: Offline Thanks Meter: 129 | ~~Next to Basic...Learn more & share More~~ As i have seen threads for begainer, it seems that they are stopped at basic but now its time to grow with practical. Learn more & Share more......... This thread is more helpfull and i m trying to make it result oriented and you can gain much output... Wbr.. ..::MumbaiGsm::.. |
10-30-2006, 11:39 | #2 (permalink) |
Member: 205738 Status: Offline Thanks Meter: 129 | But before start you should know atleast some basic parts.........by name will do.. PFO,Antena switch,Network IC,26MHz crystal,VCO, Power Ic, Audio IC, RTC, charging ic,UEM, CPU, FLASH ic, RAM ic & logic IC |
10-30-2006, 11:42 | #3 (permalink) |
Member: 205738 Status: Offline Thanks Meter: 129 | Now a days all ICs are in the form of BGA(Ball Grid Array) there are 3 types 1.DIP---dual in line package==which has both side legs... 2.QIP---Quad in line package===which has four side. 3.BGA you will find it in diagrams,schematics,Pictures............ so work hard....Good Luck Wbr... |
10-30-2006, 11:46 | #4 (permalink) |
Member: 205738 Status: Offline Thanks Meter: 129 | you should have atleast knowledge of how to measure voltage--and continuity.. As i consider all are familier with below Problems... And we will learn it step by step with Good Logic And Concepts of ALL Members Dead handset----------short---open ----leakage direct white light by inserting Battery......... charging problem... mic,speaker,ringer,vibrator,LED,display........... keypad......Big problem that is of NETWORK and software problem....contact service...contact retailer...hang... You can add more...also |
10-30-2006, 11:54 | #5 (permalink) |
Member: 205738 Status: Offline Thanks Meter: 129 | start with dead hand set...Observe all board before start Repairing..its must, Take your own time and try to identify , how handset becomes faulty.. And then Diagnostic.......Do it with Win Win Mentality..........ok check all minor things that no need to mention here....... like Battery voltage, battery connector..,batt.points on board. ok. |
10-30-2006, 11:55 | #6 (permalink) |
Member: 205738 Status: Offline Thanks Meter: 129 | check either handset is Short==open===leakage short==check continuity by analog meter..at positive and negative terminal of board(PCB) if meter shows deflection on both side means its SHORT... If its one side full and other side slight deflect means LEAKAGE... if its not any side means OPEN.... AND if its one side only then proceed NEXT STEP its common and Applicable for All mobiles |
10-30-2006, 12:25 | #8 (permalink) |
Insane Poster Join Date: Jul 2004 Location: lahore+bradford
Member: 74239 Status: Offline Thanks Meter: 0 | very good worke my friend. specialy for those who have many exprince about repairing hw and sw but dont know about these basics same like me. keep it up . thanxxxxxx |
10-30-2006, 12:55 | #12 (permalink) |
Member: 205738 Status: Offline Thanks Meter: 129 | Every hand set has FLASH Voltage which comes by pressing ON/OFF switch... It should be more than 2.5v so now you have to find the exact point where it comes........ so its also possible by diagrams,schematics,Pictures... check attachment for how to check flash voltage???????? wbr... ..::MumbaiGsm::.. |
10-30-2006, 13:02 | #13 (permalink) | |
No Life Poster Join Date: Aug 2002 Location: india Age: 63
Member: 14578 Status: Offline Thanks Meter: 831 | Quote:
pcb has it own resistens. but when meter not deflect . it mean there is +v or -v. path is open from battery connector. for easy like open fuse or open resister not shawn any deflaction. i use digital multi meter to check pcb resistence. put meter at diod check RANGE and RED PROB AT NEGATIVE BATTERY CONTEC AND BLACK PROBE AT +V. BATTERY CONTECT OF PCB . FOR EXAMPLE. OK 3310 PHONE SHAW ABT 350 READING. IF IT WTER LOGED THEN IT MAY 250 TO 300. IF IT SHAW 00 OR BUZZ CONTINUEITY SOUND,IT MEAN SHORT CIRCUIT. AND NOT SHAW ANYTHING MEAN OPEN YOU CAN CHECK ALL PHONE PCB BY THIS WAY . MAKE READING OF OK PHONE AND COMPAIR IT WITH FAULTY PHONE. WBR | |
10-30-2006, 14:31 | #15 (permalink) |
Member: 74239 Status: Offline Thanks Meter: 0 | can u explain sir about my this confiusion. when i need to chek any dead pcb voltage then what i need to do. 4 exampel i need to attatch battry to pcd or just give it voltage with any voltage addaptor 3.7 volt.if have a simpel multi voltage addaptor then is i need to just output 3.7 volt to pcb or need to calculate ampeirs aswell. b coz deferent addaptor or dc voltage suplaire gives deferent ampeires with dc volt. i thing u will understand that what i want to say u. thanx and sory 4 bad english. |
More & More Power to E-Gold | PhoneCareCenter | SAGEM JTAG UNLOCKER | 9 | 06-07-2008 16:08 |
Bb5 Ask To Rpl For Jaf & Mt.moto Via Imei.bb5 Tmobile Uk & Voda Uk And More...see | stanner_austin | Main Sales Section | 0 | 06-22-2007 11:30 |
BB5 Ask To Rpl for JAF & Moto worldwide unlock codes (Fast Turnaround) & Much more!!! | viru | Main Sales Section | 0 | 05-23-2007 23:58 |
02-04-2007 Next 3 updates released. More and More POWER every day! | GSMtricks | Multi-Box | 15 | 04-02-2007 19:27 |
I want to learn more | mobwhizhead | Hardware Repair by brands | 0 | 07-11-2002 05:35 |
