06-12-2004, 22:36 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: max232 chip
Member: 16036 Status: Offline Thanks Meter: 5 | ngage after uem change"CONTACT RETAILER" i have a ngage that i change ume on phone was working perfectly fine before after i change uem.rebuilt imei i get "DEVICE FAILER, CONTACT RETAILER" imei is ok i flsh plenty times, also factory default.simlock. full factory,uisetting formated ueser area WHEn no sim IT IS OK"insert sim n stays on" WITH SIM I GET arror can any please advise me what can be done thanks alot bye |
06-14-2004, 01:14 | #7 (permalink) |
Junior Member Join Date: Jun 2004
Member: 68879 Status: Offline Thanks Meter: 0 | Every flash has an ID Every flash has an ID, so if you change the UEM, the ID is will be mismatched one to another, or with the UEM. It's self-protection used by Nokia. Badly, you may change all of the flash memories with the same blank... pure blank memory. Then try to flash the N-gage again (usually with griffin). |
06-14-2004, 01:41 | #8 (permalink) |
Member: 16036 Status: Offline Thanks Meter: 5 | hi Ucupov,if u read correctly u will see THAT problem solved,uem was bad but thanks for that INFO also I MUST SAY-->griffin/ufs2/ufs3/progidy/twister,all these tools DO SAME thing when they flash, ANY tool can work bye |
7250i = contact service after uem chnage | Fonefingz | Nokia Hardware & Hardware Repair | 8 | 08-18-2004 01:34 |
3650 refuses to simlock after uem change | mohammed | Nokia Hardware & Hardware Repair | 3 | 01-08-2004 21:22 |
Flash phone after UEM change? | cybercellz | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 10-23-2003 06:39 |
Fail to set sp after uem chang on 3650 | panadol | Griffin | 2 | 10-17-2003 11:40 |
Fix IMEI on DCT4 after UEM change | debeliamark | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 10-13-2002 16:41 |
