09-24-2008, 16:38 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | n70 after water damaged no APE mcu detected in phone Checking for file C:\Program Files\ODEON\JAF\JAF_RM-84.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0524106 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50609201.C0 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50609201.V07 CNT Flash file: NONE APE Variant file: NONE Done! Backing up CRT data... Setting FLASH MODE Loader version: 01.10.02 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready Loader version: 01.0C.05 -> Revision: 0000 CMT Loader Ready Reading CMT NPC certificate... Reading CMT VARIANT certificate... Reading CMT CCC certificate... CCC not available... Reading CMT HWC certificate... HWC not available... Saved to C:\Program Files\ODEON\JAF\ProgData\35938000166400_CRT_backup _1733249.rpl Backup CRT OK! Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\359380001664005_CRT_backu p_1733249.pm Done! Backup LCK OK! Reading SW version...05wk07v47 Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006000C192101002200 Asic Mode ID: 00 Asic EM ID: 00000352 Asic Public ID: 2070000828BD4951D9FA2830AC6616269E4CE258 HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000 ROM ID: F28A211FCEA7B19D CMT Boot File: C:\Program Files\ODEON\JAF\Flash\UFS\rap3gv2_2nd.fg Loader version: 01.10.02 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready CMT Flash ID: 00020001 <=> SPANSION -> Type not in database CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\UFS\RAP3Gv3_algo_fps8.fg Loader version: 01.0C.05 -> Revision: 0000 CMT Loader Ready Operation took 0 minutes 6 seconds... Sending CNF Data... APE blocks present in flash file but no APE mcu detected in phone. Aborting! any solution pleease |
09-24-2008, 19:52 | #2 (permalink) |
Junior Member Join Date: Dec 2007
Member: 652444 Status: Offline Thanks Meter: 2 | change the boot ic and smps ic and flash with new var 100% from abuayaankaphone email [email protected] |
09-25-2008, 06:14 | #4 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: malaysia
Member: 429569 Status: Offline Thanks Meter: 1,543 | Quote:
your combo memory problem,,,try smps jumper first,,,if still try reball or replace combe memory,,,, | |
N70 APE blocks present in flash file but no APE mcu detected in phone. Aborting! | denadio | Nokia Hardware & Hardware Repair | 20 | 04-26-2013 10:10 |
IN N70 APE blocks present in flash file but no APE mcu detected in phone. Aborting! | Ramzan | Nokia Base Band 5 ( BB-5 ) | 6 | 12-10-2010 16:15 |
n70 APE blocks present in flash file but no APE mcu detected in phone. Aborting! | ebu mohammed-emin | Nokia Hardware & Hardware Repair | 3 | 06-25-2009 12:47 |
n70 APE blocks present in flash file but no APE mcu detected in phone | uneternity | Nokia Hardware & Hardware Repair | 8 | 06-04-2008 17:05 |
