11-07-2012, 06:42 | #4 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 740220 Status: Offline Sonork: 100.1654997 Thanks Meter: 253 | sir u say right that this is display solution but if this point is miss cel will not power on not any pulse set will be dead it works i solve many mobile by this solution it is tested many time |
08-10-2013, 15:32 | #11 (permalink) |
No Life Poster Join Date: Feb 2012 Location: kanpur
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | This is not dead solution .this is called display Solution. Becose in this modle if any one print is open neither light nor graffice will seen. Only one solution for dead mobile. First chek software if all ok change LCD if your set will not take connectivity or half flash, change power and flash IC. This is sure solution. |
The Following User Says Thank You to mahzra azra For This Useful Post: |
10-12-2013, 12:45 | #13 (permalink) | |
Junior Member Join Date: Jan 2011
Member: 1493666 Status: Offline Sonork: hai Thanks Meter: 4 | Quote:
