Old 11-07-2012, 05:24   #1 (permalink)
zoiya's Avatar
Member: 740220
Sonork: 100.1654997
Thanks Meter: 253
nokia 101 dead solution
if u like my post say thanks
The Following 4 Users Say Thank You to zoiya For This Useful Post:
Old 11-07-2012, 05:54   #2 (permalink)
ren_mglab's Avatar
Member: 1501033
Thanks Meter: 35
thank sir it looks like easy but work fine. keep it up
Old 11-07-2012, 06:30   #3 (permalink)
shama's Avatar
Member: 333037
Sonork: 100.1611244
Thanks Meter: 77
hey this is not solution for dead this solution for display problem
Old 11-07-2012, 06:42   #4 (permalink)
zoiya's Avatar
Member: 740220
Sonork: 100.1654997
Thanks Meter: 253
sir u say right that this is display solution but if this point is miss cel will not power on not any pulse set will be dead it works i solve many mobile by this solution it is tested many time
Old 06-12-2013, 14:15   #5 (permalink)
Member: 1918106
nokia 101
dead problem any another solution...???
The Following User Says Thank You to piyush22 For This Useful Post:
Old 06-15-2013, 13:28   #6 (permalink)
Member: 1022587
Thanks Meter: 2
nice sol bro its work for me plz keep it up.....
Old 06-16-2013, 05:00   #7 (permalink)
Member: 1903049
its working for meeeeeeeeeeeeee
Old 06-16-2013, 11:10   #8 (permalink)
pintu.pattnaik1's Avatar
Member: 1351981
Sonork: 100.1640597
Thanks Meter: 48
its not working for me
Old 08-10-2013, 12:48   #9 (permalink)
brutalgsm's Avatar
Member: 1982017
Thanks Meter: 58
i think white screen solution correct me im wrong..
the same like this..
Old 08-10-2013, 13:35   #10 (permalink)
Member: 1019081
Sonork: 1234
thanks ets working 10000000000000000/
Old 08-10-2013, 15:32   #11 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
This is not dead solution .this is called display Solution.
Becose in this modle if any one print is open neither light nor graffice will seen.
Only one solution for dead mobile. First chek software if all ok change LCD if your set will not take connectivity or half flash, change power and flash IC.
This is sure solution.
The Following User Says Thank You to mahzra azra For This Useful Post:
Old 09-20-2013, 12:54   #12 (permalink)
Member: 1881946
Sonork: 9944216963
hi bro its not working ya...... u have any other solution
Old 10-12-2013, 12:45   #13 (permalink)
Member: 1493666
Sonork: hai
Thanks Meter: 4
you are wrong without this connection sometime set will be dead or white display this connection will cause for those two problems i solved many dead set and white display by make that jumper
Old 10-12-2013, 12:47   #14 (permalink)
Member: 1493666
Sonork: hai
Thanks Meter: 4
scan in mxkey or atf if it shows lcd print missing........make jumper to lcd or its not connecting short or replace bsi resistor....change lcd......reball or replace cpu
Old 10-12-2013, 18:16   #15 (permalink)
Member: 1718801
Sonork: 100.1647443
Thanks Meter: 8
Only one solution for dead mobile. First chek lcd test fail and ok change LCD if your set will not take connectivity
Page generated in 0.18933 seconds with 10 queries
