Old 01-14-2014, 07:49   #31 (permalink)
Member: 1831904
Sonork: jithucelcom
i tried this solution but same problm any other solution?
Old 01-14-2014, 08:42   #32 (permalink)
nafe2me's Avatar
Member: 977479
Sonork: 100.1638508
Thanks Meter: 795
post self test report here...
Old 01-14-2014, 08:45   #33 (permalink)
Member: 1759766
Thanks Meter: 28
bro which pins are you applied the jumper do you have a clear shot thanks
Old 01-15-2014, 14:36   #34 (permalink)
ABUU YUUNUS's Avatar
Member: 319112
Thanks Meter: 164
Smile
Don't let the phone sniff life out of you! A thousand and one other good jobs are coming your way.:coo l:
Old 02-06-2014, 09:51   #35 (permalink)
snisar's Avatar
Member: 517952
Sonork: Nisar mongaM
Thanks Meter: 495
Replase the BSI resistor....
Old 02-06-2014, 16:18   #36 (permalink)
ashuk deab nath's Avatar
Member: 1215691
Thanks Meter: 43
Nokia C2-03 After few second restarting
here flash log...
MXKEY [USB Smart Card Reader 0], SN: C0872CD2
Using device: USB ROM
Connection status: UHCI:HUB::USB 1.10 (Full-speed)
Driver: NMWCD, ver: 7.1.32.84
Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device synchronized.
CPU: XGOLD 213
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.37
EBL version: Quantum_Bootloader_10.37_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 00EC 3012 - 23280002 [Samsung ]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI:
RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD__back.RPL"
Processing file: rm702__07.63.mcusw
Downloading item CODE:rm702__07.63.mcusw_ebl_psi.fls, num block: 4, size: 28 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.343 s
Erasing area 0x40040000-0x4005FFFE ...OK
Programming completed in 0.359 s
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.484 s
Erasing area 0x40280000-0x41D3FFFE ...OK
Programming completed in 34.875 s
Checksum verified (0x787E)
Processing file: rm702__07.63.ppm_i
Downloading item CUSTackage_i.ppm_ebl_psi.fls, num block: 1, size: 4.19 MB
Erasing area 0x41DC0000-0x421F1136 ...OK
Programming completed in 5.563 s
Checksum verified (0x844F)
Processing file: rm702__07.63.image_i_059H286
Downloading item CUSTackage_i_059H286.image.fls, num block: 1, size: 13 MB
Erasing area 0x424C0000-0x43E1FFFE ...OK
Programming completed in 17.765 s
Checksum verified (0xA624)
Total time for flashing process(boot+erase+write) was 3 min 2.532 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia C2-03 USB Phonet, PORT_ID: 359065049884042
Verifying communication to device OK.
Phone type: RM-702 (C2-03)
SW version: V 07.63 17-08-12 RM-702 (c) Nokia
Imei plain: 35906504988404-2
Product code: 059D473
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: 06150123008027, ver:
Imei net: 35906504988404
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 0.094 s
*Flash latest verson flash file
*Clean and rehot pcb but same problem
Please help me
Old 04-04-2014, 12:05   #37 (permalink)
Registered User
Member: 1768177
Sonork: +918187845143
Thanks Meter: 23
[email protected] TheCompleteMobileSolutions
states of the phone is dead ...
flashing with atf ,
flashing is ok but one error is show (lcd test failed )
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
TIME STARTS HERE
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: STMicroelectronics
Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
Extended Information: Multiple Bank / Burst / 1.8v
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_007.200
FIRMWARE Image Found...
Number of Sections: 03
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 03
FIRMWARE Erase Block: 0x00000000~0x0001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 24576 bytes
Data Checksum: F5BE
Uploading Data Blocks to phone...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 03
FIRMWARE Erase Block: 0x00800000~0x00BFFFFE
Start Erasing...
Block Erase Done...
Data Size: 4128768 bytes
Data Checksum: BFB7
Processing Section 03 of 03
FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE
Start Erasing...
Block Erase Done...
Data Size: 1697536 bytes
Data Checksum: 2B05
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_007.20mh
PPM Image Found...
Number of Sections: 01
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x00100000~0x0061813E
Start Erasing...
Block Erase Done...
Data Size: 5341504 bytes
Data Checksum: 47D8
PPM Data Blocks uploaded to phone...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm7690_nai07.20mh_nlt
CONTENT Image Found...
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x00E60000~0x00F49FFE
Start Erasing...
Block Erase Done...
Data Size: 958464 bytes
Data Checksum: BB37
CONTENT Data Blocks uploaded to phone...
Exit Flash Mode Done...
Time Elapse : 00:04:32
You must Factory Reset the phone to enable the
ringtones and other customized settings to work
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
MCU: V 07.20 30-03-12 RM-769 (c) Nokia
IMEI: 353654055460122
Product Serial Number: 3D65DAFBI
Product Code : 059J2D0
Module Code : 0204874
Basic Production Code: 059P5G1
PPM SW Version : V 07.20 30-03-12 RM-769 (c) Nokia MH
ADSP Version : p+V 07.20\n30-03-12\nRM-769\n(c) NMP\nmh_nlt
MCU SW Version : V 07.20 30-03-12 RM-769 (c) Nokia
HW Version : 3000
UEM Version : 1328
UPP Version : 8850
LCD Version : UNKWN: IDs: 00:00:00
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 0000000000040002
ASIC : 11
PROVIDER : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
ST_LCD_TEST : FAILED
Phone Cannot Enter Normal Mode if LCD
is Damaged or LCD is not Properly
Connected to the Main PCB
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
apply this jumber.. 100% working.....
phone is on condeshion.....
Good work nice post
Old 07-12-2014, 08:06   #38 (permalink)
Member: 986980
Thanks Meter: 2
I need 101 bsi ways itz very urgent plz................
Old 07-12-2014, 22:29   #39 (permalink)
Pratheesh T K's Avatar
Member: 866865
Sonork: 1645198
Thanks Meter: 182
It is only work if lcd test is falce
Any way good job
Old 08-14-2014, 14:05   #40 (permalink)
smurugan's Avatar
Member: 1214929
Thanks Meter: 9
Booting Phone...
TIME STARTS HERE
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_006.650
Data Block Found...
IMAGE Certificate Block Sent Successfully...
IMAGE Erase Block: 0x00000000~0x0001FFFE
Start Erasing...
Block Erase Done...
Data Checksum: F5BE
IMAGE Data Blocks uploaded to phone...
IMAGE Erase Block: 0x00800000~0x00BFFFFE
Start Erasing...
Block Erase Done...
Data Checksum: D598
IMAGE Erase Block: 0x00C5D000~0x00E5FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 047E
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_006.65aa
Data Block Found...
IMAGE Erase Block: 0x00100000~0x006060BE
Start Erasing...
Block Erase Done...
Data Size: 5267648 bytes
Data Checksum: 901A
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm7690_nai06.65aa
Data Block Found...
IMAGE Erase Block: 0x00E60000~0x00F17A3E
Start Erasing...
Block Erase Done...
Data Size: 752192 bytes
Data Checksum: 2802
Time Elapse : 00:04:15
5, 4, 3, 2, 1...
MCU: V 06.65 07-11-11 RM-769 (c) Nokia
IMEI: 356341057032904
Product Serial Number: 9CDF18BBI
Product Code : 059P7M1
Basic Production Code: 059S217
PPM SW Version : V 06.65 07-11-11 RM-769 (c) Nokia AA
ADSP Version : p V 06.65\n07-11-11\nRM-769\n(c) NMP\naa
MCU SW Version : V 06.65 07-11-11 RM-769 (c) Nokia
HW Version : 3000
UEM Version : 1328
UPP Version : 8850
LCD Version : TPO:BARACOAv92 HX5081
ASIC : 11
ST_LCD_TEST : PASSED
OK
OK
OK
OK
OK
OK
Old 08-14-2014, 14:06   #41 (permalink)
smurugan's Avatar
Member: 1214929
Thanks Meter: 9
my mobile is not on plz hellp me
Old 08-14-2014, 18:57   #42 (permalink)
Member: 1295540
Thanks Meter: 10
br old solution ...... any new solution thxxxx.........
Old 08-14-2014, 18:57   #43 (permalink)
Member: 1295540
Thanks Meter: 10
br old solution ...... any new solution thxxxx.........///////////////
Old 08-16-2014, 07:28   #44 (permalink)
nafe2me's Avatar
Member: 977479
Sonork: 100.1638508
Thanks Meter: 795
check all tracks if lcd test failed
[IMG]http://3.bp.********.com/-O68YKxdoB64/TzFM-iYmiOI/AAAAAAAAA3Y/xZnJVqmDksQ/s1600/Nokia+100+LCD+LIGHT+SOLUTION.jpg[/IMG]
Old 09-12-2014, 11:50   #45 (permalink)
smurugan's Avatar
Member: 1214929
Thanks Meter: 9
my 101 flashing fully completed and also normal mode in fbus but when i tried to switch on with battery it should not on ..it is in a same dead condition ....
Page generated in 0.26958 seconds with 8 queries
