11-28-2012, 11:03 | #1 (permalink) |
Junior Member Join Date: Nov 2012
Member: 1843214 Status: Offline Sonork: 100-1608030 Thanks Meter: 3 | Nokia 101 White Display 100% Tested Solution Nokia 101 White Display Problem Repairing Solutions are available in the following article. Also you will find Nokia 101 Display Ways and Jumpers information in the diagrams further in this post. Nokia 101 White Display Problem Nokia 101 White Display Solution Nokia 101 Blank Display Please Note that we will edit these solutions or add new ones if found in this page at any time in the future. So feel free to come back any time on this page to stay up to date. Here Are Nokia 101 White Display Problem Solution. Please Observe Carefully. If you have further Questions please don’t hesitate to leave a comment. Note: Every diagram we post on *********.com is tested by one or more members of our team. Still Use them at Your Own Risk we are not responsible if these solutions may cause any harm to your phone. GSM-FAZAL |
The Following 5 Users Say Thank You to Fazal Rabi Khan For This Useful Post: |
06-14-2013, 07:16 | #7 (permalink) |
Freak Poster Join Date: May 2009 Location: saharsa bihar
Member: 1033632 Status: Offline Sonork: [email protected] Thanks Meter: 62 | try to this |
11-20-2013, 18:41 | #9 (permalink) |
Junior Member Join Date: May 2010 Location: mumbai
Member: 1299469 Status: Offline Sonork: [email protected] Thanks Meter: 0 | VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_006.650 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00000000~0x0001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24576 bytes Data Checksum: F5BE Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00800000~0x00BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4128768 bytes Data Checksum: D598 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1697536 bytes Data Checksum: 047E Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_006.65ag PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00100000~0x005E7A3E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5143104 bytes Data Checksum: CE2A Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm7690_nai06.65ag CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00E60000~0x00F1803E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 753728 bytes Data Checksum: BB5C Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:04:17 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 06.65 07-11-11 RM-769 (c) Nokia IMEI: 354584053704743 Product Serial Number: 67EC476BI Product Code : 059P7M3 Module Code : 0204874 Basic Production Code: 059P5G1 PPM SW Version : V 06.65 07-11-11 RM-769 (c) Nokia AG ADSP Version : p V 06.65\n07-11-11\nRM-769\n(c) NMP\nag MCU SW Version : V 06.65 07-11-11 RM-769 (c) Nokia HW Version : 3000 UEM Version : 1328 UPP Version : 8850 LCD Version : UNKWN: IDs: 00:00:00 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000040002 ASIC : 11 PROVIDER : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : FAILED Phone Cannot Enter Normal Mode if LCD is Damaged or LCD is not Properly Connected to the Main PCB FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK Changing Phone Mode... (Wait for 10 seconds) Successfully set to : Normal |
11-20-2013, 18:43 | #10 (permalink) |
Member: 1299469 Status: Offline Sonork: [email protected] Thanks Meter: 0 | ST_LCD_TEST : FAILED Phone Cannot Enter Normal Mode if LCD is Damaged or LCD is not Properly Connected to the Main PCB |
12-13-2015, 12:35 | #15 (permalink) |
Junior Member Join Date: Oct 2014 Location: Jl.Kh.Dewantara No.12 Mepanga
Member: 2268438 Status: Offline Sonork: 100.1667123:Flasher Thanks Meter: 1 | help my nokia 101 LCD blank white... |
The Following User Says Thank You to Ichank Fisheri For This Useful Post: |
