10-07-2013, 15:20 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Location: Pakistan
Member: 152961 Status: Offline Thanks Meter: 11 | nokia 110 complete flash Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0100F4B4 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: nmwcdc, ver: 7.1.32.84 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Battery voltage: 5068 mV Waiting for USB device removal ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.49 EBL version: Quantum_Bootloader_10.49_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35329105893180 IMEI_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK LOCK120_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35329105893180_ back.RPL" Processing file: 3998CC21_rm827__03.04 (1).mcusw Downloading item CODE:rm827__03.04.mcusw_ebl_psi.fls, num block: 4, size: 26 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.359 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.406 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.609 s Erasing area 0x40280000-0x41B3FFFE ...OK Programming completed in 34.297 s Checksum verified (0x74A0) Processing file: B44A851C_rm827__03.04 (1).image_m2_059N2R0 Downloading item CUSTackage_m2_059N2R0.image.fls, num block: 1, size: 13.88 MB Erasing area 0x421C0000-0x43E1FFFE ...OK Programming completed in 19.063 s Checksum verified (0x6508) Processing file: AADC66F1_rm827__03.04 (1).ppm_m2 Downloading item CUSTackage_m2.ppm_ebl_psi.fls, num block: 1, size: 3.02 MB Erasing area 0x41BC0000-0x41EC4AA2 ...OK Programming completed in 4.266 s Checksum verified (0xE7C0) Total time for flashing process(boot+erase+write) was 8 min 46.328 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C2-00 USB Phonet, PORT_ID: 3866BCE6 Verifying communication to device OK. Phone type: RM-827 (Nokia 110) SW version: V 03.04 20-04-12 RM-827 (c) Nokia Imei plain: 35329105893180-7 Product code: 059N417 Battery voltage: 5078 mV, current: 155 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: M2 Language Pack: - not available. Master code: 7141661452 Camera config: NI00CS00000401022F03, ver: 010.009 Imei net: 35329105893180 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000004000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
10-08-2013, 13:08 | #4 (permalink) |
Junior Member Join Date: Jul 2013 Location: Astara, Iran
Member: 1982063 Status: Offline Sonork: ID: [email protected] Thanks Meter: 7 | Thank you. Choose c2.01 model and flash now |
