04-20-2009, 20:19 | #1 (permalink) |
Product Manager Join Date: Sep 2003 Location: Indonesia Age: 45
Member: 39251 Status: Offline Sonork: 100.1618715 Thanks Meter: 6,186 | Ichal_spy Hardware Analisys here ill upload some analysis of hardware problem that we success finishing here.... br Borneoflasher Training and Service Centre Indonesia..... ichal_spy |
The Following 23 Users Say Thank You to Rizal Arsyad Dini For This Useful Post: |
04-20-2009, 20:30 | #2 (permalink) |
Member: 39251 Status: Offline Sonork: 100.1618715 Thanks Meter: 6,186 | KEypad and Display Light failure anaylisi and solution i receive nokia 6300 no light at display and keypad.... Steps : 1. check vbat at L2304 = normal 2. check Pwm pin from tahvo ic at j2316= normal 1.8v 3. check vled out from Light ic = normal Summary Light Ic dan tahvo Ic is normal Next Step : chek out put from n2401 at test point j2428 there is no voltage... normally... its must be 18volt Analysis : Failure at ic n2401 Then i check the way at n2401... i find that there is between L2403 to N2401 is not conneted.... solusition : Jumper L2403 to pin 4 at N2401 result : Display ligh is normal .. But keypad light still not normal B]Next Step:[/B] cek output at r2408 = 18v Check out put at r2418 = no voltage...nomally it must be 15volt COLOR="Blue"]Analysis :[/COLOR] Failure at v2401 solusi : because i dont have this componenet (v2401) i make a trik with make a jumper from r2408 to r2419 Result... : Keypad light is normal ... and Display Light is normal too ichal_spy sorry because the pict in Indonesian.... |
The Following 18 Users Say Thank You to Rizal Arsyad Dini For This Useful Post: |
04-20-2009, 20:35 | #3 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Rwanda
Member: 883190 Status: Offline Sonork: 1587513:khalifa Thanks Meter: 87 | special man in hardware. we need some one like you here in rwanda |
The Following 3 Users Say Thank You to kamanzi For This Useful Post: |
05-05-2009, 22:39 | #5 (permalink) |
Member: 39251 Status: Offline Sonork: 100.1618715 Thanks Meter: 6,186 | 6680 BT Error I found Nokia 6680 error at Bluetooth... (Operation failed) Measurement : Check Vio at c6035 = 1.8v normal Check Vregout At C6036 = 0 (It should be 2.8v) Analisis.... Vregout Regulator (N6031) is damaged.... Step.... Make Jumper between Vaux (C1470) 2.8v to Vregout C6036 Result...... Br ichal_spy Borneoflsher Trainig Centre Indonesia |
The Following 14 Users Say Thank You to Rizal Arsyad Dini For This Useful Post: |
05-06-2009, 05:57 | #11 (permalink) |
Member: 39251 Status: Offline Sonork: 100.1618715 Thanks Meter: 6,186 | Case Nokia 6630 Signal Problem.... Object : Step : Searching manual on phone at setting, Network...... Manually... REsult : No Operator Found So in this case the problem is at RX Part or Receiver Measurement step.... 1. Check Rx i/q di J7508, J7509, J7510, J7511..... Not Good datas... so the problem is around RF Ic not rap problem.. cause the data come from rf ic to Rap.. 2. Check Control Vco at pin out cp at rf ic... Result is Noise.. so the problem is at CP Out line (Control VCO).. at BB5 phone the problem is always damaged at capasiror 2n2.. so i change it... after change.. i check again and its not noise anymore.... after that i search manually the network again.. result.. all operator is found... but after selec an operator its cant acces.. its show NO Accest at display... so problem now is at TX (Transmitter).. RX Problem is solved.... Next step.... Check Control VCO for TX at cp out line at Vinku result.... No line... its mean VCO for Vinku not working.... Next step.... Check VCO Coltage at c7555... No Voltage... its must be 2.8v Check vreg2 at C7548 No Voltage too its must be 2.8v too cause its be at same way with vco voltage... Check way between c7555 and cc7548 result the way is OK... Summary..... Damaged is at VCO Voltage.. its not be 2.8volt..... Solution.... Find another voltage... example Vreg1 with same value.... Make jumper betweenVreg1 (C7543) yo Vreg2 (C7548)... after make jumper I check control VCO is ok... and not noise.... Turn on the phone.. and the result is.... Best Regards... ichal_spy Borneoflasher Training Centre Indonesia |
The Following 12 Users Say Thank You to Rizal Arsyad Dini For This Useful Post: |
05-08-2009, 17:13 | #14 (permalink) |
Member: 39251 Status: Offline Sonork: 100.1618715 Thanks Meter: 6,186 | 3100 No Signal analisis.... Step : Searching Manual no operator found... so the problem is at RX part (Receiver) step.... Check Rx i/q at J611,J612,J613 dan J614.. thya the data is like this.. so.. RF part is ok,,,, and we dont have to check RF Voltage, RF Bus, RF CLock etc... its must be OK cause rx i/q is ok..... Summary.... the problem is on PM or UEM next step.... Write good pm ... result... Same.. next step reball UEM... and the result is... [IMG][/IMG] br |
The Following 6 Users Say Thank You to Rizal Arsyad Dini For This Useful Post: |
Any Mobile Hardware Solution Here. | mizancoxr | Hardware Repair by brands | 11 | 11-22-2007 07:30 |
all siemens hardware solutions here | ::.::SOUFIZ GSM::.:: | Siemens Hardware Repair Area | 21 | 05-08-2007 18:41 |
nokia n73 hardware soulation here | aleenasager | Nokia Hardware & Hardware Repair | 1 | 10-14-2006 00:57 |
All Siemens E-Gold Software and Hardware solution here | .::Unlocker.:: | E-Gold Based Phones | 2 | 02-08-2006 13:14 |
