08-03-2009, 06:09 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: INDIA
Member: 542743 Status: Offline Thanks Meter: 81 | nokia 1100 auto off after 30 sec imei ok when power on with sim network ok any idea\ any solution ? very urgent........... thanx in advance |
The Following 2 Users Say Thank You to chhoton For This Useful Post: |
08-03-2009, 08:11 | #5 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 339455 Status: Offline Sonork: 100.1589401 Thanks Meter: 86 | Hello check uem imei,if it is corrupted you must replace uem and if it is ok and uem have valid imei you must write flash checksum or rpl. in many cases uem imei corrupted and must replac it. |
The Following User Says Thank You to mazmaz1 For This Useful Post: |
08-03-2009, 08:33 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: RWP Pakistan
Member: 420821 Status: Offline Sonork: 100.1603493 Thanks Meter: 731 | 100% uem problem........................... wbr Gul Hassan |
The Following 2 Users Say Thank You to gul_hassan528 For This Useful Post: |
08-03-2009, 08:42 | #7 (permalink) |
The Following User Says Thank You to gul_hassan528 For This Useful Post: |
08-03-2009, 08:58 | #8 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Inside of GsmhostinG
Member: 707582 Status: Offline Sonork: 100.1620432 Thanks Meter: 334 | may be your IMEI check sum bad so need RPL bye a rpl from server and write RPL your problem solved 100% you take UEM from 1100 then phone permanantly dead. because its GLUED IC care full.so dont try that(UEM REPLACING) YOUR OWN RISK post result best regards |
1100 power off after 30 sec | Sagitarious | Nokia Hardware & Hardware Repair | 16 | 06-22-2010 21:00 |
1100 switch off after 30 sec | Sapandeep | Nokia Hardware & Hardware Repair | 8 | 02-26-2009 13:17 |
2600 Auto Off After 30 Sec | sharaz191 | Nokia Hardware & Hardware Repair | 11 | 06-25-2007 11:15 |
nokia 2300 turns off after 30 sec | Mounir | Twisterflasher | 1 | 09-12-2004 22:05 |
