01-21-2008, 15:59 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: (¯_PAKISTAN_¯)
Member: 491455 Status: Offline Sonork: On My LAB Thanks Meter: 296 | Nokia 1100 Battery Low Battery is fully harge. I already change battery. |
The Following User Says Thank You to ARS.Rehman For This Useful Post: |
01-22-2008, 18:47 | #8 (permalink) |
Freak Poster Join Date: Apr 2007 Location: Gwalior (MP) India Age: 36
Member: 480959 Status: Offline Thanks Meter: 49 | Brother Have U Change The Battery Connector Change Them And Post Ur Result |
The Following User Says Thank You to Sandeep_$tomar For This Useful Post: |
02-14-2009, 10:08 | #11 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DERAMOBILE DGKhan pakistan
Member: 388454 Status: Offline Thanks Meter: 1,101 | if set is turn off exactly after 30 second then it is uem problem . and it is not easy to solve this problem. otherwise PA problem. change the PA. |
02-14-2009, 10:47 | #12 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: IBADAN, OYO STATE, NIGERIA
Member: 319112 Status: Offline Thanks Meter: 164 | Quote:
Go through the following steps and it is hoped you will come out with desired result. 1. Make sure that there are no traces of liquid damage on the pcb and if there is any, just clean properly with nitrocellulose thinner. 2. Ensure that the battery connector is okay. 3. Check the charge diode if it is not short to ground on its positive pole. 4. If all the above-mentioned are okay, try full-flashing the phone. 5. If the fault still persists, then you will need a good power amplifier, and the problem should be solved by then. | |
The Following User Says Thank You to ABUU YUUNUS For This Useful Post: |
03-04-2009, 17:39 | #14 (permalink) | |
No Life Poster Join Date: May 2006 Location: zambia
Member: 272581 Status: Offline Thanks Meter: 118 | Quote:
and also how do i change PA, i have a hot air station with gauge of air 0-8, and gauge of Heat 0-8, what are the right settings of air and heat gauge to change PA? and what positon should i point the nozzle, above PA ic, or below, under the mainboard? | |
03-04-2009, 18:33 | #15 (permalink) | |
Freak Poster Join Date: Feb 2009
Member: 969467 Status: Offline Thanks Meter: 37 | Quote:
nokia 6300 battery low | kosmoscomputer | Nokia Hardware & Hardware Repair | 11 | 12-05-2011 00:25 |
1100 battery low | thamizh | Nokia Hardware & Hardware Repair | 4 | 07-10-2009 19:13 |
1100 battery low problem | madhar_k | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 09-28-2008 14:12 |
nokia 1100 batt low | barthosyn | Nokia Hardware & Hardware Repair | 2 | 06-17-2008 12:43 |
1100 Battery Low | Sadeeq | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 08-14-2005 11:31 |
