03-19-2007, 21:28 | #2 (permalink) |
No Life Poster Join Date: Mar 2005 Location: United Arab Emirates Age: 43
Member: 130244 Status: Offline Sonork: 100.1609062 Thanks Meter: 143 | check ur body may b its problem....after that check is ur set is water damage or not clean key pad and check again if not work reflow keypad ic's best of luck |
06-25-2008, 14:22 | #4 (permalink) |
Junior Member Join Date: Jun 2007
Member: 520203 Status: Offline Thanks Meter: 0 | Do the steps... 1. Check & clean the connector between keypad and mother board 2. Re-hot the Keypad IC with good flux 3. Change the IC Last edited by Ambiliprajeesh; 06-25-2008 at 14:28. |
7610 keypad problem... | Yassen | Nokia Hardware & Hardware Repair | 4 | 10-18-2006 16:14 |
7610 Keypad Problem | Okilim | Nokia Hardware & Hardware Repair | 3 | 09-02-2006 22:36 |
7610 keypad problem | kulu | WD2 & APE (Symbian Phones) | 1 | 12-19-2005 05:20 |
7610 Keypad Problem | malta | Nokia Hardware & Hardware Repair | 6 | 02-02-2005 18:29 |
