Nokia 1100 EMIE-000000000000004? need help mates! I got a Nokia 1100 phone with EMIE as above,guys is it possible to do? If so Pls guide me through d steps !! a bit urgent!! Regards [email protected] |
patch imei or reflow uem or replace new uem & write rpl file good luck |
Only write rpl,if tou dont have rpl backup |
replace blank uem ic * write rpl.....only trusted & working solution regards PUNEET14884 :) |
write rpl.....only trusted & working solution |
Write Rpl.................. |
thanks! Mates ! gt few things to make sure 1-can i write d RPL with d same UEM i have 2-when i write d RPL does it has be da same EMIE NO?(IN RPL) 3-How can i remove a glued UEM sorry if my question r silly!!! |
please show me any video how i can remove glued uem in 1100 |
I m also want to know , how to remove glued uem. any one have any video. please post hare or mail it to me. [email protected] |
hot air! you need to try first! if you fail, do it again until you got mastered, UEM is almost same cost than second hand n1100, & others say: RTO-"return to owner" hehe! |
Change a UEM then write rpl |
try using fufenu software....it calculate the corrupted imei number... so, ung can ur rpl to write it the phone...tested so many times |
Mates ! i have try'd with all mesures of heat n ****, still by the time i remove UEM ,mother board will be distroy'ed there is kind aflux type chemical as i know to use to remove UEM safly ! what do u say........am i rite? |
fufenu Quote:
visit www.fufenu.com contact [email protected] |
