nokia 1100 insert sim needed nokia 1100 insert sim solutoin needed pls. |
change or use jumper for sim ic.this is small ic near sim reader also check small capacitors near sim reader. |
so many time posted this sol.u have to use only search button ..................... br JAGGI |
there are many post in this forum search and get the perfect solution |
1 Attachment(s) try this solution ..........:) |
thanks i will try it |
hi onley change sim ics 100% ok .....................! ..::Mr Fone::.. |
use 1100 1600 solution to do it .it will work |
check the battery pinout and try to adjust the middle pin ...................regards |
good work...................... |
Change sim ic or jumpering |
