Old 02-05-2009, 11:09   #1 (permalink)
Registered User
Member: 470854
Thanks Meter: 10
1110 1112 1600 signal
nkia 1110 1112 1600 signal problem signal ic pa direct signal very low we use other componet resister and capter use signal power very up
please help me
The Following User Says Thank You to Usman Arshad For This Useful Post:
Old 02-05-2009, 12:10   #2 (permalink)
Member: 681180
Thanks Meter: 18
try apply this jumper maybe your problem will be solve...
http://www.4shared.com/file/84546250...20problem.html
The Following User Says Thank You to audvid2_bd For This Useful Post:
Old 02-05-2009, 12:35   #3 (permalink)
Registered User
Member: 470854
Thanks Meter: 10
brother when we use signal ic pa mobile work when use jumper jazz call ok telenor call fail and mobile no show signal on power splie
Old 02-05-2009, 13:25   #4 (permalink)
Member: 963505
Thanks Meter: 50
Reball hager ic & change matual coppeler, Change pfo
Reball cpu ic, erase then flash then write pm file
Solve the problem of 1600, 1110i, 1112, 6030, 2610, 2310
Old 06-23-2009, 16:38   #5 (permalink)
Member: 52636
Thanks Meter: 5
THE DIFFERANT BYTWING THE CHINA MODEL AND ORIGINAL MODEL HELP?
[email protected]
Old 06-23-2009, 19:40   #6 (permalink)
chamak-liton's Avatar
Member: 735673
Thanks Meter: 3,101
link pic 100% ok but only one network supaded.tri change pa,Reball hager ic & change matual coppeler.
NOKIA 1110/1112/1600 Battery low SolutionNOKIA 1110/1112/1600 Battery low Solution gsm junction Nokia Hardware & Hardware Repair 3 05-06-2013 13:02
nokia 1110 1112 1600 signal Usman Arshad Nokia Hardware & Hardware Repair 1 02-06-2009 04:50
nokia 1110 1112 1600 signal problem Usman Arshad Nokia Hardware & Hardware Repair 0 02-05-2009 14:04
Singtone In 1110 1112 1600 george2006 Nokia Multimedia 16 01-31-2009 07:41
MT BOX vs 1110 1112 1600 mvtamele MT-BOX 1 12-11-2006 15:55
Page generated in 0.16922 seconds with 9 queries
