Old 08-08-2006, 00:07   #1 (permalink)
Member: 70744
Sonork: none
Thanks Meter: 3
1100 not charging without charger
greets,this 1100 shows "not charging" without charger connected,i tried to reheat but prob.. persist.thnx
The Following User Says Thank You to veli For This Useful Post:
Old 08-08-2006, 12:34   #2 (permalink)
shinod's Avatar
Member: 55363
Thanks Meter: 146
1100
the pcb is water damaged if please clean that board or wirte pm
Old 06-18-2008, 19:12   #3 (permalink)
Member: 461164
i have the same problem pls i need fast reply thnks
Old 06-18-2008, 23:51   #4 (permalink)
Member: 55967
Thanks Meter: 9
some times need fast charger to work on this.maybe the curent of the charger must be up to 300-500 mA due to bad cleaning from water wrong connections .try first to clean very good the led connectios and after try better charger .may be need stabilized current or voltage........
Old 06-19-2008, 00:04   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
IT SOUNDS UEM PROBLEM.
Old 06-19-2008, 07:07   #6 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
first clean ur pcb properly.........
if not solve its uem problemmmm
Old 06-19-2008, 07:12   #7 (permalink)
mughalG's Avatar
Member: 315789
Thanks Meter: 3,428
yes 100% UEM damege
br
Old 03-23-2009, 20:12   #8 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
this is a uem fault.......................................
The Following User Says Thank You to azez.sd For This Useful Post:
1110 auto say not charging without charger plz help amanhalwara Nokia Hardware & Hardware Repair 3 11-26-2007 09:31
5140i NOT charging without charger, works good with Charger :-) dazexy Nokia Hardware & Hardware Repair 0 10-23-2007 12:04
3310 not charging without connect charger uwenk98 Nokia Hardware & Hardware Repair 3 03-07-2004 22:21
T20S show charging without charger conected?!? jivkobg Sony Ericsson Hardware Repair 6 07-26-2002 00:48
Charging without charger Moc Old Ericsson Phones & Sony Phones 1 06-04-2002 00:01
Page generated in 0.17478 seconds with 10 queries
