Old 11-22-2007, 04:27   #1 (permalink)
Member: 513721
Thanks Meter: 52
nokia 1110 1600 contact service new solution
1- Full erase
2- Fash your phone using it original firmware
3- write 1100 pm
4- Flash it again with its original firmware
5- Write its original PM values
6- 110% your contact service is gone
7- Unlock if needed
8- End
The Following User Says Thank You to mr_chauhan18381 For This Useful Post:
Old 11-26-2007, 09:04   #2 (permalink)
Member: 615661
Thanks Meter: 3
1100 pm supported in 1110 and 1600 are sure for this problem????????????????????????
Old 11-26-2007, 09:23   #3 (permalink)
owoeye's Avatar
Member: 218859
Thanks Meter: 2
how do i full erase.using jaf box
Old 11-27-2007, 12:03   #4 (permalink)
rajeshkanna's Avatar
Member: 582515
Thanks Meter: 70
when i trying to flash 1110 with jaf.. but the jaf window shows
Getting MCU ID
MCU ID: 0x2201
FLASH ID0: 93400A41 -> Unknown flash chip Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0
FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: 8D 40 0A 41 50 A8 C0 E2 5D 99 8B E4 43 EE 45 CC
Checking RAM for ALGO...
Can't find flash loader for this phone...Aborting!
so what can i do further... whats the perfect solution..
Old 01-01-2008, 12:06   #5 (permalink)
nishaon's Avatar
Member: 225229
Thanks Meter: 90
Getting MCU ID
MCU ID: 0x2201
Reball or change your Fash Chip.
The Following User Says Thank You to nishaon For This Useful Post:
Old 01-01-2008, 12:48   #6 (permalink)
X-TRA's Avatar
Member: 303790
Thanks Meter: 290
Originally Posted by mr_chauhan18381 View Post
1- Full erase
3- write 1100 pm
7- Unlock if needed
8- End
hi there
nope! bro its not a healthy solution if set on contact service due to software then just do unlock option it will be work perfactly well i tryyyyyy ur solution at 3 set at the time but failed to get result
wbr
ahmad
Old 01-01-2008, 16:48   #7 (permalink)
Member: 248245
Thanks Meter: 85
Originally Posted by X-TRA View Post
hi there
wbr
ahmad
can u define the name of box, becoz i flashed 2310 with UFS-3 but not done.
Old 01-02-2008, 08:52   #8 (permalink)
X-TRA's Avatar
Member: 303790
Thanks Meter: 290
hi there
i done it with jaf
Old 01-02-2008, 12:18   #9 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 636
just unlock with JAF 85% okkkkkkkkkkkkkkkkk
The Following User Says Thank You to ansari123 For This Useful Post:
Old 01-02-2008, 13:11   #10 (permalink)
meknes gsm's Avatar
Member: 376587
Thanks Meter: 8
thanks for thi soulition !!!!!!!!!!!!!!!!!!
Old 01-02-2008, 22:29   #11 (permalink)
Member: 139211
hy guys..i have a strange pblm with my 1110i..first i have "contact service" ...now a have "sim not valid" in normal mode and CS when i put battery.....!!!
Old 01-02-2008, 23:28   #12 (permalink)
abumu3ed's Avatar
Member: 462224
Sonork: 100.1586374
Thanks Meter: 103
1- Full erase
3- write 1100 pm
7- Unlock if needed
8- End
if your problem is software, then no need to do all this, just full erase, reflash your phone to the latest version, write pm and unlock. if you still have CS, it's 1000% hardware.
Old 01-03-2008, 07:42   #13 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
Thanks Meter: 524
contact service come for two causes
1. softwere
2. hardwere
if softwere then not need to do a lot thing
just erase and full flash with latest version file, if not ok then
this is hardwere problem
Old 01-30-2008, 03:27   #14 (permalink)
Member: 185776
Thanks Meter: 73
1. softwere
2. hardwere
s u r correct.If hard ware try this.I had done lot of pieces.Remove key pad ic and buzzer ic ,then replace new ics.100% ok.if problem same uem,upp problem.
Old 03-23-2008, 09:19   #15 (permalink)
Member: 307420
Thanks Meter: 17
hello sir water damaged cell 111oi i have cleaned pcb with chemical after that comes contact service , now erased, flash with new version but problem now still plse help me
1110 1600 contact service new solution 10000000% ok mr_chauhan18381 Nokia Hardware & Hardware Repair 55 09-28-2015 11:12
Nokia 1110 rh70 contact service solution 100%(INGS*****) alammov Nokia Hardware & Hardware Repair 10 02-15-2011 18:06
1110/12,2310, 6030 contact service new solution Parminder Singh Nokia Hardware & Hardware Repair 25 11-12-2009 13:29
1110,1600 contact service shaikapsar Nokia Hardware & Hardware Repair 3 11-22-2008 16:31
nokia 1110 1600 contact service ayaz ali Nokia Hardware & Hardware Repair 8 04-05-2007 13:40
Page generated in 0.24531 seconds with 10 queries
