07-24-2005, 17:07 | #1 (permalink) |
Freak Poster Join Date: Nov 2003 Age: 45
Member: 43545 Status: Offline Thanks Meter: 7 | 6600 charging problem i have nok. 6600 when i put on charger it will show nothing .......i change{ fuse f380,l380, v381 } but still same is there any hint pll.....thanks //tanmay// |
07-25-2005, 00:42 | #2 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | hardware check please measure the output voltage when you plug in the charger (without battery offcourse ) if output = 1.5 volt so no problem hardware you just need good pm if output less than 1.5 volt you have problem in uem br., |
07-25-2005, 08:22 | #3 (permalink) | |
Freak Poster Join Date: May 2005 Location: ksa Age: 52
Member: 149600 Status: Offline Thanks Meter: 11 | Quote:
07-25-2005, 11:19 | #4 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: india Age: 49
Member: 107636 Status: Offline Thanks Meter: 100 | Quote:
best regards | |
09-09-2005, 13:26 | #7 (permalink) |
Freak Poster Join Date: Mar 2003 Age: 47
Member: 25392 Status: Offline Thanks Meter: 10 | i have a problem with a 6600 the phone it is not charging ..... after i insert charger nothing is hapening.. i replaced conector fuses almost everything on charging circuit.. full erase..full flash..good pm... still nothing ..hope is not uem ..any ideea nenmobil |
09-09-2005, 20:31 | #8 (permalink) | |
Insane Poster Join Date: Jul 2005 Location: Sudan-Khartoum Age: 46
Member: 157834 Status: Offline Thanks Meter: 1 | Quote:
6600 charging problem | slpclk | Nokia Hardware & Hardware Repair | 1 | 12-15-2009 16:49 |
I have 6600 charging problem | Nishant jain | Nokia Hardware & Hardware Repair | 1 | 01-30-2006 17:56 |
6600 charge problem | opo | Nokia Hardware & Hardware Repair | 2 | 01-19-2006 16:29 |
Nokia 6600 charging problem | lexwon | Nokia Hardware & Hardware Repair | 3 | 12-03-2005 16:05 |
6600 charging problem uem fault | sanjeev_in | Nokia Hardware & Hardware Repair | 0 | 09-09-2005 20:49 |
