06-04-2010, 12:42 | #1 (permalink) |
Freak Poster Join Date: Dec 2009
Member: 1173626 Status: Offline Thanks Meter: 59 | nokia 1110i dead but i flesh with mxkey please reply me /////////thanks in advance Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0000 0001 [unused/removed] FlashID1: 0000 0001 [unused/removed] ExtBUSC: 0000 0001 0002 0003 0004 0005 0006 0007 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...ASIC type: 2 UEM Imei: Empty Flash Imei: F6DB5C740D8BCB Invalid IMEI Data, No RPL backup will be made for this phone. Error saving rpl backup ! Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Processing file: rh930_nai7.02mg as CNT [DCT4,DCT4 ALGORITHM] size: 156.00 KB Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033 Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) flashing terminated ! Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Device IO error: The handle is invalid (code: 6) Flashing terminated with error(s) in 42.531 s RX Buffer: 000000000000000042B372 |
06-04-2010, 17:29 | #4 (permalink) |
Insane Poster Join Date: Jan 2009
Member: 957309 Status: Offline Sonork: sharifuddin_s Thanks Meter: 17 | sir n-81 8gb flashing in mxkey for using usb falsh but my phone is IMEI is 1234512345 pls help me Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Processing file: RM179_21.0.010_prd.C00 as MCU [BB5,XSR 1.5] size: 46.91 MB Supported RAP Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101011105, 400C192101011105, 4003192101021103, 400C192101021103, 4003192101021105, 400C192101021105, 4003192101031103, 400C192101031103, 4003192101031105, 400C192101031105 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 423005F RAP SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] RAP EM0 ID: 00000295 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 12B0001148860058C53621C6990C4F9E53226B17 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C RAP ROM ID: A8C1D6713E691FF8 [ADL] Flashing CMT Update Server Data, ULO: 0x3B00 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, XSR: 0x1F8F5F bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 284A7379 [ADL] Verifying communication to device OK. Partitioning.... Partitioning complete Erase size: 92.37 MB Flash programming ... CMT PAPUBKEYS: E70C21157D5AB5AF61AAD376910751FB06D6E9FD (RAP Certificate 45 V1) written. Programming completed in 1 min 30.110 s Processing file: RM179_21.0.010_prd_0801.V08 as PPM [BB5,XSR 1.5] size: 28.75 MB Supported RAP Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101011105, 400C192101011105, 4003192101021103, 400C192101021103, 4003192101021105, 400C192101021105, 4003192101031103, 400C192101031103, 4003192101031105, 400C192101031105 Erase size: 40.31 MB Flash programming ... Programming completed in 56.640 s Processing file: RM179_21.0.010_002_erase_uda.fpsx as CNT [BB5,XSR 1.5] size: 204 Bytes Supported RAP Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103 Erase size: 26.37 MB [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia N81 USB Generic, ID: 2B0011F5 [ADL] Verifying communication to device OK. Flashing completed in 4 min 0.609 s Phone Type: RM-179 (Nokia N81) SW Version: V 06wk41v62.4 04-12-08 RM-179 (c) Nokia Imei plain: 12345610654321-? Product Code: 0545898 ApeVariant: 21.0.01021.0.010_08.01 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 4 min 6.328 s Nokia USB ROM detached. |
