10-16-2007, 07:49 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Location: My country is Kenya. Age: 39
Member: 153875 Status: Offline Thanks Meter: 35 | N80 charging problem Thanks. |
10-17-2007, 06:51 | #3 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: http://meo786.forumotion.com/ Age: 50
Member: 465162 Status: Offline Thanks Meter: 683 | Dear, check it Muhammad Afzal Meo Quote:
The Following 2 Users Say Thank You to meo786pk For This Useful Post: |
10-17-2007, 08:38 | #4 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Philippines - Saudi Arabia
Member: 396326 Status: Offline Thanks Meter: 229 | Quote:
11-09-2007, 10:45 | #5 (permalink) |
Member: 153875 Status: Offline Thanks Meter: 35 | Thanks everybody for your responses. Will try each solution stated by each of you and will post working results after am through. Thanks |
11-09-2007, 12:06 | #6 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 465901 Status: Offline Thanks Meter: 45 | last time i had faced the same problem, my set was showing that it is charging the battery but after a long time battery power was remainng the same, i take the +ve supply from the charging point make a jumper through a diode to the +ve of the battery connector and then it was charging the battery properly it was working well wish |
11-19-2007, 18:40 | #7 (permalink) | |
No Life Poster Join Date: Apr 2002 Location: South Spain Age: 41
Member: 10905 Status: Offline Thanks Meter: 109 | Quote:
Wbr | |
04-09-2008, 18:24 | #9 (permalink) |
Freak Poster Join Date: Oct 2007 Location: oman<>kerala Age: 43
Member: 602589 Status: Offline Sonork: 0000001 Thanks Meter: 822 | I have nokia N80 which has charging problem in that when I am charging it shows that its charging but in the actual sense it is not taking in power. When you remove the charger is when you realise that it was not charging. Again at the same time its draining power because lets say you charge battery seperately, the power cant last the whole day. Sometimes virus cause these problems but i dont think its virus so dont tell me about formating and scanning for virus etc. Any expert to post the solution with detailed pictures. I know there are so many experts in here. Thanks. IT Z 100%CHARGING IC PROBLEM CHANGE IT |
N80 Charging Problem | bmw-gsm | Nokia Hardware & Hardware Repair | 0 | 03-14-2009 10:34 |
N80 charging problem | aslikethat | Nokia Hardware & Hardware Repair | 10 | 09-27-2007 08:54 |
N80 charging w/ USB | Zerokewl | Nokia Base Band 5 ( BB-5 ) | 2 | 07-06-2007 15:31 |
Nokia N80 Charging Problem | twin army | Nokia Hardware & Hardware Repair | 2 | 02-27-2007 11:16 |
N80 charging problems | bayproject1 | Nokia Base Band 5 ( BB-5 ) | 0 | 12-17-2006 23:05 |
