Nokia 1112 Strange Keypad problem..Experts Help me. Hello Masters, I got a nokia 1112 in keypad problem. I changed the keypad ic. Problem is that when i press 1 both 1 and 4 number display on screen, when 2 then 2 and 5 and when 3 then 3 and 6. Remaining keypads are ok. After changing the keypads problem is same. Plzzzzz Help Me. |
Here is the solution for keypad problem in 1112 even after replacing keypad IC 1 Attachment(s) Apply the flux and reflow the the UPP as shown in the diagram. |
i reballed the cpu but problem is same. |
Clean care fully keypad ic point use magnify glass or microscop there some dust making those prob |
sir keypad ic is ok and also the board,s point. problem is not keypad ic. problem is somthing else. |
i had same problem but mine was solved by changing keypad ic.............. |
hrsturtuyhr tu65uyahn |
just try another key pad ic it is problem of key pad ic |
post result soon Best REGARD Me Fone |
I had same problem Just change keypad IC and see. |
keypad ic problem Quote:
I had same problem . i solve it by changing CPU + keypad IC |
see dear it repaired many phones did the same way u talk about that comes cause the keypad IC its leg touch each others so when u press in number 2 for example it does the two functions of no, 2 and five in the same way u have to keep the legs of the crystal away from the other which besides. waiting for ur reply |
