nokia 112 charging not supported (need help) nokia 112 charging not supported (need help) thanks |
first replace d charging fuse then check if still same then remove marked varistor . post result |
thanks for the reference ................................ |
SARCAR SIR i try this ( first replace d charging fuse then check if still same then remove marked varistor) but same problem ....... Br// Saini |
only battery change Nokia battery bL-6 supported battery.. |
