11-10-2008, 16:14 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Bhilwara(Rajasthan)India
Member: 643992 Status: Offline Sonork: 100.1625367 Thanks Meter: 180 | Nokia 1200 1st boot not ok by ufs. |
The Following User Says Thank You to jkniji For This Useful Post: |
11-10-2008, 18:51 | #2 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 675717 Status: Offline Thanks Meter: 125 | First rehot UEM with flux if no good result then rehot UPP with flux if no good result reball UPP if not good reball UEM.Remamber at the first clean the board well.Best of luck. |
11-10-2008, 19:00 | #4 (permalink) | |
No Life Poster Join Date: Feb 2008
Member: 706300 Status: Offline Thanks Meter: 147 | Quote:
" bro since it is dropped in water so itz hard to tell u from my place whether the short lies,wt i mean is most parts are involved , so do one thing make it clean & check how much short it possess less the short lesser will be the suspects & vice-versa, so bro check short & post, thanx" Last edited by mobilespeed; 11-10-2008 at 19:06. | |
11-10-2008, 19:14 | #5 (permalink) | |
Insane Poster Join Date: May 2008
Member: 771625 Status: Offline Thanks Meter: 46 | Quote:
if no current you can not software it cant read. check it all? hope can help? | |
11-11-2008, 08:12 | #7 (permalink) |
Junior Member Join Date: Jun 2008
Member: 800101 Status: Offline Sonork: 77718 Thanks Meter: 5 | this for u if all yr cable and box are install properly and all in a good conditon, i think you've to open yr phone cover (casing ) than put the software cable and click check if the problem still happen the second trick after click check follow by clicking on botton softly,till Ok. Do not re hot/ball yr UEM or UPP cause this case is only between your cable, box and flash IC How we will get your Uem is bad if it doesn't connect, so i suggest u to find it out follow step by step thanks. [email protected] |
Nokia 6300 1st Boot Err, RAPX NOT BOOTING.." | amit123 | Nokia Hardware & Hardware Repair | 1 | 09-18-2009 20:57 |
rh-99 nokia 1200 v5.71 not support by hwk sarasoft | CIMO | HWK | 2 | 01-16-2009 16:07 |
nokia 3310 1st Boot Ok, 1st Boot Err: 00 00 | subhadara | Nokia Hardware & Hardware Repair | 3 | 02-27-2007 18:15 |
nokia 3310 1st Boot Ok, 1st Boot Err: 00 00 | subhadara | Nokia Hardware & Hardware Repair | 3 | 02-27-2007 08:54 |
Nokia 6600 1st boot ok 2nd Error | walli Turab | Nokia Hardware & Hardware Repair | 7 | 11-27-2006 08:10 |
