Old 06-18-2009, 06:28   #16 (permalink)
habibuddin's Avatar
Member: 441231
Thanks Meter: 206
Originally Posted by md jawad View Post
i got same problem i flashed in jaf and re hot ram and power ic 100% ok
1200/1208/1650 those model set are ring tone on then restart problem is
not of hardware Mr.md jawad. u have tested urself but this is not proper
solution mr. jawad. it's simple factory setting by manual then ok br. i have
tested many set 1200/1208/1650. rehot flash& power ic always risky.anyway
thanks for ur contribution.
B.R.
habibuddin.
The Following User Says Thank You to habibuddin For This Useful Post:
Old 05-11-2010, 15:30   #17 (permalink)
Member: 387116
Sonork: 100.1650000
Thanks Meter: 176
Originally Posted by Miftahudin View Post
Nokia 1200 Restart problem when select ring tone any idia..........
only setting restore set 10000000000000% ok
The Following User Says Thank You to M kashif For This Useful Post:
Old 05-11-2010, 16:40   #18 (permalink)
Member: 639554
Thanks Meter: 6
Just go tophone (settings)-(restore factory settings, then type 12345) problem solved!!!!!!!!! also works with 1650.
The Following User Says Thank You to Ernest Appiah For This Useful Post:
Old 05-16-2010, 13:25   #19 (permalink)
Crazy Poster
Member: 1249417
Thanks Meter: 4
not work same problem please help for for this problem
The Following User Says Thank You to bacha123 For This Useful Post:
Old 05-16-2010, 14:53   #20 (permalink)
imranieman's Avatar
Member: 749175
Sonork: imranieman
Thanks Meter: 73
its software broblem
The Following User Says Thank You to imranieman For This Useful Post:
Old 08-08-2010, 01:38   #21 (permalink)
Member: 601591
Thanks Meter: 86
hello bros dont kill your phone by rehot just go to factory setting on
your phone and enter 12345 as normal nokia code 100000000000000000000000% ok
by me
The Following 2 Users Say Thank You to baloo2000 For This Useful Post:
Old 08-12-2010, 07:08   #22 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
Set full factory and solved
The Following 3 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 09-13-2010, 20:55   #23 (permalink)
Member: 601591
Thanks Meter: 86
just go to reset factory setting inside the phone
and reset it.10000000000000% ok.
The Following User Says Thank You to baloo2000 For This Useful Post:
Old 01-18-2011, 21:11   #24 (permalink)
Member: 96064
Thanks Meter: 6
ok man لخخي وللملململللللللممممممممممممممممممممممممممممممممممم ممممممممممممممممممممممممممممممممممممممممممممم ممممم
The Following User Says Thank You to oman_jeep For This Useful Post:
Old 01-19-2011, 21:53   #25 (permalink)
Member: 326059
Thanks Meter: 5
yes man make normal factory seting 10000% tested by me
The Following User Says Thank You to nasrygobran For This Useful Post:
Old 02-03-2011, 07:52   #26 (permalink)
Member: 1121927
Sonork: 213213213
Thanks Meter: 7
,.,.try to reheat upp sir.,,
The Following User Says Thank You to lesterdaisy122 For This Useful Post:
Old 06-22-2011, 10:12   #27 (permalink)
Member: 1194678
Sonork: babamax
Thanks Meter: 4
First flash your phone if not solve then......
Try this......
http://img20.imageshack.us/img20/4453/1200restart.jpg
The Following User Says Thank You to babamax For This Useful Post:
nokia 1200 restart sachintvmobile Nokia Hardware & Hardware Repair 7 12-15-2009 03:45
1200 restart problem jakkarzoya_2511 Nokia Hardware & Hardware Repair 5 07-22-2009 19:56
nokia 1200 restarting sachin_udai Nokia Hardware & Hardware Repair 11 12-01-2008 08:34
1200 restart problem nadirghazi Nokia Digital Core Technology 4 ( DCT-4 ) 7 07-03-2008 09:48
Page generated in 0.19268 seconds with 10 queries
