01-29-2009, 04:20 | #1 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 460316 Status: Offline Thanks Meter: 22 | 1110i wet unit action taken: wash the board with tinner flash it with the original and hinger version, flashing is good and show test mode after flashing but hte phone doesn not power on and dont even charge. IS THERE ANY HARD WARE SULOTION FOR THIS. . . |
01-29-2009, 04:23 | #2 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,515 | 1110i Quote:
Friend!This is software problem.Full Flash Phone After unlock. Problem Solved. BR Haicha | |
01-29-2009, 05:37 | #5 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: IBADAN, OYO STATE, NIGERIA
Member: 319112 Status: Offline Thanks Meter: 164 | Quote:
There is more to cleaning a pcb that has liquid attack. You must make sure that you clean well the inner part of the system connector (most enginners will call it charging port), and some other hidden parts. This requires a lot of patience and hope. You also need to check the continuity of the battery connector pins with your multimeter and also ensure that the flash interface is clean. You may now follow this procedure in flashing the phone and perhaps you could make a headway. Establish a good connection between your software module and the phone and erase the flash in the phone completely and then flash the phone. One important thing you must note here is that you have to make use of the highest version of flash file as there is no way to detect the version of flash that was in the phone before it died. This is because if it happens that you have downgaraded the phone there is no way you can get it powered on until you have been able to write in the appropriate flash that was in it before or a higher one. | |
help N70 wet unit | colonelrte | Nokia Hardware & Hardware Repair | 3 | 10-09-2007 18:04 |
GD88 dead/ wet unit | gancellshop | Panasonic | 0 | 07-21-2006 02:53 |
V3 Wet unit. | remylebeau | Motorola Hardware Repair | 0 | 10-30-2005 05:15 |
V3 Wet unit.. | remylebeau | Motorola Hardware Repair | 0 | 10-25-2005 05:41 |
6680 wet unit w/ weak signal | scotch7 | Nokia Hardware & Hardware Repair | 0 | 10-17-2005 16:18 |
