10-15-2008, 09:03 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Gaming Zone Age: 43
Member: 202298 Status: Offline Thanks Meter: 35 | Nokia 1208 Hang Problem..... I am facing problem nokia 1208 hang and restart. When i power on it's work fine for some time like one or two minutes. after that it's doing problem hang or some time direst restart without hang some hang and restart. I already try to full erase and then full flash but problem not solve.. then i decide to open phone and try to change upp.. after change upp with working phone but not solved. "fualted phone upp work fine other phone" . So after read many post i decide to change keypad Ic then SIM Is and then change sound IC ..... but problem still there in phone .... after deep testing through Oscilloscope i find fualt on flash IC , So i change with working phone flash IC. after that i am so confused because problem show again.. "after chang flash IC phone was work perfect for 5 minutes." after testing and thing one day . I decide to change UEM , so i change this one ... Now problem is same........ Plz Plz plz help me i am so confused. Waiting perfece reply... Ps. plz note i already chang PA for testing but not solved. |
The Following 5 Users Say Thank You to farrukh mobiles For This Useful Post: |
10-15-2008, 09:54 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | change both flash ic & uem from working phone otherwise replace new uem and write rpl because here is a imei issue |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
10-17-2008, 06:13 | #5 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Nepal Age: 38
Member: 799195 Status: Offline Sonork: all gsm cdma tool is best Thanks Meter: 116 | u need to full erase and flash wit latest flash file and write pm and also do patch 100% problem solved |
The Following User Says Thank You to Rajan chhetri For This Useful Post: |
10-17-2008, 15:48 | #7 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 582515 Status: Offline Thanks Meter: 70 | i have nokia 1110 , 1200, 1208, 1209, 1650 all are the handsets are dead ... when i trying to flash these phones with jaf Getting MCU ID MCU ID: 0x2201 FLASH ID0: 84039406 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0 FLASH ID1: 04010400 <=> Flash ID not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: 77 40 45 A5 B4 44 B4 45 F7 66 E7 A1 57 82 15 63 Checking RAM for ALGO... Can't find flash loader for this phone...Aborting! please tell me the exact solution for this problem........ i am waiting for your reply.. lots of thanks in advance |
The Following User Says Thank You to rajeshkanna For This Useful Post: |
08-25-2009, 15:19 | #9 (permalink) |
Junior Member Join Date: Jun 2007
Member: 534555 Status: Offline Thanks Meter: 2 | I have solve this problem to day by change the UPP, or you may try to reball first if its failed than change UPP, 100% solved!!!!! *** Luck...bro! |
The Following 2 Users Say Thank You to mikhael_junior For This Useful Post: |
08-25-2009, 22:35 | #11 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | for hang and rerstart first reball upp if same change cpu its tested |
The Following 2 Users Say Thank You to HUM For This Useful Post: |
08-26-2009, 05:55 | #14 (permalink) |
No Life Poster Join Date: Nov 2007 Location: pakistan®
Member: 639462 Status: Offline Sonork: 100.160880 Thanks Meter: 392 | change both flash ic & uem from working phone otherwise replace new uem and write rpl because here is a imei issue |
The Following User Says Thank You to khawajagsm For This Useful Post: |
02-23-2010, 21:56 | #15 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 574100 Status: Offline Thanks Meter: 160 | change to cpu and erase flash then write software with pm and complete ui setting 100000000% ok tested by me |
The Following User Says Thank You to abdeu77 For This Useful Post: |
Nokia 1208 hang & restart | vvsory | Nokia Hardware & Hardware Repair | 33 | 08-04-2015 02:49 |
1208 hang problem | irfan99 | Nokia Hardware & Hardware Repair | 16 | 12-25-2010 18:38 |
nokia 1208 hang without charger | jagdish1747 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 10-17-2009 06:40 |
nokia 1208 hang | speed infotech | Nokia Hardware & Hardware Repair | 1 | 09-20-2009 11:23 |
