Old 04-17-2004, 12:19   #1 (permalink)
patric's Avatar
Member: 8228
Sonork: 12399830
Thanks Meter: 136
nokia 1100 charging problem
i have a nokia 1100 that have a charging problem
when u plug charger it shows only battery and don't charge..
i try to flash it but no solution
thanx for help
The Following User Says Thank You to patric For This Useful Post:
Old 04-17-2004, 20:49   #2 (permalink)
Member: 39601
Thanks Meter: 13
Check all the battery connectors soldering , R100 ( 47k thermistor ) , and R200.
Old 05-08-2004, 18:43   #3 (permalink)
Member: 14716
Thanks Meter: 15
1100 not charging
In my experience 1100 with BR-5C battery will not charge, but if you put BL-5C or BL-4C it will.
WBR
The Following 2 Users Say Thank You to ammar For This Useful Post:
Old 03-13-2005, 08:04   #4 (permalink)
Member: 12724
Thanks Meter: 30
http://forum.gsmhosting.com/vbb/show...00#post1069700
Old 03-13-2005, 13:16   #5 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
try another charger on phone .
try rising pins interface laying on-top of the charging port position.
try checking charging area port again.
try another battery on your phone.
try checking battery connector on your phone .
try cleaning all interface , before used in charging port area.eg charging port interface pin.
try checking on broken lines along charging areas .
try this now..................
bestman.
Old 03-13-2005, 15:21   #6 (permalink)
Member: 116891
Thanks Meter: 15
The worst reason is defected UEM
Old 09-24-2009, 14:35   #7 (permalink)
Member: 532221
thanx for help
pls give me solution
Old 09-24-2009, 18:19   #8 (permalink)
chamak-liton's Avatar
Member: 735673
Thanks Meter: 3,101
100% uem problem.............
nokia 1100 charging problem WHED Nokia Hardware & Hardware Repair 2 03-02-2009 09:05
Nokia 1100 Charging problem please help its urgent jewelmobiles Nokia Digital Core Technology 4 ( DCT-4 ) 1 07-24-2008 16:21
Nokia 1100 Charging problem jewelmobiles Nokia Digital Core Technology 4 ( DCT-4 ) 1 07-24-2008 15:58
nokia 1100 charge problem Usman5833157 Nokia Hardware & Hardware Repair 4 03-24-2008 07:37
Nokia 1100 Charging problems ebendup Nokia Hardware & Hardware Repair 2 06-27-2006 08:15
Page generated in 0.21698 seconds with 9 queries
