08-18-2008, 01:39 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | ..::nokia 1208 no indication when insert charger::.. i remove the two parts near uem but this solution not work any idea for this problem wbr, GSMHUNT FORUM |
08-18-2008, 03:42 | #4 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 384098 Status: Offline Thanks Meter: 33 | dear hum,i hope this link can help u. http://forum.gsmhosting.com/vbb/show...208+local+mode good luck! |
08-18-2008, 04:22 | #6 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | chk this pic the set comes in the problem it not show charging indication so i try to remove this part but in handling this print also damaged,now set show local mode when i insert battery wbr, GSMHUNT FORUM |
08-18-2008, 06:10 | #7 (permalink) |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | [QUOTE=HUM;3576750]chk this pic the set comes in the problem it not show charging indication so i try to remove this part but in handling this print also damaged,now set show local mode when i insert battery its uem problem first remove uem and check track of charging from inside the uem to charging fuse if track is ok first reball uem and thhen check charging.. . . ..it may also fix ur local mode problem by renballing it............if it doesnt work its mean u have to change uem.......... good luck... and post result....... |
08-18-2008, 18:18 | #8 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | i solved local mode problem now wat i do for charging....................... insert charger nothing happen wbr, GSMHUNT FORUM |
08-19-2008, 02:46 | #10 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | |
..::x700 Blinks When Insert Charger::.. | HUM | Samsung Hardware Repair | 3 | 03-30-2009 07:44 |
..::samsung C230 Turn Off When Insert Charger::.. | HUM | Samsung Hardware Repair | 3 | 12-05-2008 07:06 |
..::nokia 3100 when insert charger no indication::.. | HUM | Nokia Hardware & Hardware Repair | 8 | 05-06-2008 18:56 |
E530 no respone when inserting charger | mccm | Samsung Hardware Repair | 0 | 08-30-2006 01:25 |
V800 no key when insert sim card | gattus | Sony Ericsson Hardware Repair | 1 | 06-15-2006 18:03 |
