Old 09-11-2012, 13:39   #1 (permalink)
Member: 856059
Thanks Meter: 124
Smile nokia 2700c contact service(plz help)
Phone type: RM-561 (Nokia 2700 classic)
SW version: V 09.98 06-09-10 RM-561 (c) Nokia
Imei plain: 35832403680357-7
Product code: 0590213
Battery voltage: 4722 mV, current: 103 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: NIMMIIIIRRFF094B2F01, ver: 002.014
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 358324036803577
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
now what i do
Old 09-11-2012, 18:01   #2 (permalink)
Member: 1767975
Thanks Meter: 27
your set showing security test failed
write a good pm and ui setting all will be ok
Old 09-12-2012, 13:35   #3 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
make sx4 auth & write pm field 1 & 309
Old 09-12-2012, 13:50   #4 (permalink)
exit_exit2050's Avatar
Member: 872692
Thanks Meter: 51
With mxkey 1s backup rpl 2th write pm pmm ath
Old 09-12-2012, 14:06   #5 (permalink)
Member: 856059
Thanks Meter: 124
i m also write pm file after write its show same message
SIMLOCK_TEST passed
Old 09-12-2012, 15:46   #6 (permalink)
imrankhan0143's Avatar
Member: 1796401
Sonork: 100.1623409
Thanks Meter: 56
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
now what i do
first save full rpl data with mxkey
save sim lock data
then full erese
full flash
write rpl data
write simlock
then write sx4 pm 100% solution
Page generated in 0.17408 seconds with 8 queries
