Old 06-15-2011, 11:10   #1 (permalink)
sanjeevjha's Avatar
Member: 1270242
Sonork: 1602438
Thanks Meter: 161
nokia 1280 not power on when i put the battery
nokia 1280 when i connect the atf box bus check or scan phone ..phone is power on . but i put the battery or power on phone phone is not power on ......plz suggest me ???????????????????
Old 06-15-2011, 11:14   #2 (permalink)
Member: 1485341
1280 no power on battery
brother try another battery or check battrey conectoer
Old 06-15-2011, 11:21   #3 (permalink)
sanjeevjha's Avatar
Member: 1270242
Sonork: 1602438
Thanks Meter: 161
battery is working fine other mobile connector is ok phone is on by hwk normal mod
Old 06-15-2011, 11:33   #4 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,110
Brother I Think Your Battery Connector Middle Point is Mitch math Problem.
Regard Brother Palash Ahammad
Old 06-15-2011, 11:37   #5 (permalink)
sanjeevjha's Avatar
Member: 1270242
Sonork: 1602438
Thanks Meter: 161
all point track is ok
The Following User Says Thank You to sanjeevjha For This Useful Post:
Old 06-23-2011, 03:24   #6 (permalink)
Mind Power's Avatar
Member: 338106
Thanks Meter: 55
ya i too faceing this problem plz can any gsm friend provide any solution
Old 06-28-2011, 07:50   #7 (permalink)
Mind Power's Avatar
Member: 338106
Thanks Meter: 55
is that any solution for this
Old 06-28-2011, 08:11   #8 (permalink)
Member: 1333523
Thanks Meter: 22
post ufs info log here.
mosly lcd problam
change lcd.
Old 06-28-2011, 18:37   #9 (permalink)
Member: 1539798
Sonork: 12345
Thanks Meter: 21
bro charjing ok plzz other soltioin
Old 07-27-2011, 10:48   #10 (permalink)
Fazil's Avatar
Member: 282757
Sonork: 100.1606418
Thanks Meter: 34
no solution . . . . .still warring
somebody help me
Old 07-27-2011, 12:05   #11 (permalink)
.::MAHABUB::.'s Avatar
Member: 939797
Sonork: 100.1601089
Thanks Meter: 359
re-hot power ic (uem) your problem will be solved 100000%
Old 11-25-2011, 10:18   #12 (permalink)
Member: 1132141
Thanks Meter: 24
if the set shows charging but no power on then there must be power ways missing. check the power switch way
Old 11-26-2011, 15:10   #13 (permalink)
dj.comcell's Avatar
Member: 887859
Sonork: dj.comcell
Thanks Meter: 13
on/0ff way is broken chek it,if ok rehot uem ic....
Old 04-06-2012, 05:04   #14 (permalink)
HIRENSHAH9's Avatar
Member: 1477622
Sonork: 100.1646445
Thanks Meter: 26
remove bsi rasistor & short it
Old 04-09-2012, 08:21   #15 (permalink)
lovepreet's Avatar
Member: 667436
Thanks Meter: 154
1280 Power Switch Ways
Page generated in 0.32649 seconds with 10 queries
