Old 01-20-2011, 23:22   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
..::1202 sim card rejected problem::..
1202 show sim card rejected when i insert sim card
only jazz sim working
set is not blocked
all locks open
already change sim ic
also change uem + flash ic from ok set
flash with higher version
Old 01-20-2011, 23:45   #2 (permalink)
iliya _angelov's Avatar
Member: 903701
Sonork: leo7
Thanks Meter: 119
change sim ic 100% from worked phone
or rehot procesor
good luck friend
Old 01-20-2011, 23:50   #3 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
sim ic is ok
now i think upp faulty
The Following User Says Thank You to HUM For This Useful Post:
Old 01-20-2011, 23:57   #4 (permalink)
disel center's Avatar
Member: 299401
Sonork: facebook:Ahmad Majzoub
Thanks Meter: 233
Originally Posted by HUM View Post
sim ic is ok
ofcurse upp problem
sim lines has gon to cpu
The Following User Says Thank You to disel center For This Useful Post:
Old 01-20-2011, 23:58   #5 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
set is not blocked
all locks open
Simple give Vflash Volt at VCC SiM , prob will b solve
Rashid Ahmed Nadeem
sim ic is ok
The Following User Says Thank You to r a nadeem For This Useful Post:
Old 01-21-2011, 00:06   #6 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
thnx alot sir after a long time u reply my post
i m very thankful to u
sir please give picture
thnx again
Old 01-21-2011, 01:11   #7 (permalink)
chohansahib's Avatar
Member: 719944
Thanks Meter: 2,117
Rashid Ahmed Nadeem
Aoa Rashid Ahmed Nadeem bro
hope ur fine dear........plz explain abt this solution .and upload pic for easy to understand.
thanx alot in advance
Chohansahib
The Following User Says Thank You to chohansahib For This Useful Post:
Old 01-21-2011, 02:10   #8 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
Old 01-21-2011, 03:58   #9 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
thnx again
Chohansahib
In some cases some sim not work, its fault of Vsim , actually Vsim not work or short from UEM , it will be better if you cut link between UEM and Vsim , give here Vflash volt , in some cases it create display prob , in this case give + batt at Vsim ,
Rashid Ahmed Nadeem
The Following 9 Users Say Thank You to r a nadeem For This Useful Post:
Old 01-21-2011, 13:24   #10 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
not working...............................
still same
Old 01-21-2011, 14:08   #11 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
Originally Posted by disel center View Post
ofcurse upp problem
dear! sim lines are going to uem not upp. see this thread for more detail.
good luck,
Old 01-21-2011, 21:44   #12 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
ofcurse upp problem
sim ic is ok
good luck,
Sim ways not come from UPP , its come from UEM , i agreed , consider schematic ,
Brother HUM , if you tried my solution then your UEM faulty, although you have change UEM already
Rashid Ahmed Nadeem
Old 01-21-2011, 22:16   #13 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
yes sir i already change uem
Old 01-22-2011, 00:56   #14 (permalink)
Member: 601591
Thanks Meter: 86
check the reading of the legs if normal try change the sim card holder 100% solved
Old 01-22-2011, 05:33   #15 (permalink)
Member: 1441250
Sonork: 100:1602230
Thanks Meter: 199
thanks...................
SIM restriction pending -- what does it mean? Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-17-2011 10:05
Page generated in 0.22583 seconds with 10 queries
