01-06-2009, 14:12 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 749916 Status: Offline Sonork: 1647914 Thanks Meter: 43 | nokia 1600 power on |
The Following User Says Thank You to kumar_pvj For This Useful Post: |
01-06-2009, 14:17 | #2 (permalink) |
No Life Poster Join Date: Apr 2008 Location: IN MY PC
Member: 745721 Status: Offline Sonork: 100.1605292 Thanks Meter: 2,390 | full errese fast then full flash & ui setting............................. |
The Following 4 Users Say Thank You to R@jusat For This Useful Post: |
01-06-2009, 14:37 | #3 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | 1.erase flash 2.flash latest version 3.write pm 4.click init simlock it is auto detect for patch unlock thats it... |
11-21-2010, 13:44 | #5 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Dadu Sindh Pakistan Age: 37
Member: 1322713 Status: Offline Sonork: 100.1663786 Thanks Meter: 254 | dear sir i hv one nokia 1600 i flash it now flashing is complete but not power on with battery. here is logs Getting MCU ID MCU ID: 0x2201 FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 7.02 10-12-07 RH-64 (c) NMP HW version: 0501 PCI version: UEM version: 1328 UPP version: 8705 RFIC version: 0500 DSP version: P05w06.v34 LCD version: UNKWN: IDs: 00:ff:00 PPM version: V 7.02 10-12-07 RH-64 (c) NMP IA ADSP SW version: V 7.02\n10-12-07\nRH-64\n(c) NMP\nia Production serial number: KCJ478902 Product code: 0525434 Module code: 0202591 Basic production code: 0520754 Flash code: Order number: 0000000 Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 359337037883108 IMEI spare to net: 3A 95 33 07 73 88 13 00 IMEI SV to net: 33 95 33 07 73 88 13 40 F5 Master Code: 5037050752 Phone type: RH-64, Software version: 7.02, Language Pack: IA User code: ے# Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-64.ini Saved INI not found, loading INI list... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ Searching for default location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done! |
11-21-2010, 14:35 | #7 (permalink) |
No Life Poster Join Date: May 2006 Location: Pakistan
Member: 277937 Status: Offline Thanks Meter: 48 | same this to me in 1112 flash with jaf,mx key flashing ok but cant power on need expert opinion also heat up the board remove reggey lokal mode resictence check bsi line change lcds but nooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooo>>>>???? |
Nokia 1600 Power On Button Not Work | sajidrana | Nokia Hardware & Hardware Repair | 1 | 08-24-2008 09:26 |
1600 powers on when u insert te battery | hany elsaghir f | Nokia Hardware & Hardware Repair | 2 | 01-07-2008 00:52 |
1600 power on problem | totalmanish | Nokia Hardware & Hardware Repair | 11 | 09-23-2007 18:11 |
nokia 1600 power off problem help me | israrudin | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 07-23-2007 11:24 |
nokia 1600 power | jacob magembe | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 11-10-2006 10:26 |
