Old 11-22-2010, 12:29   #1 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,687
nokia 1616-1280-1800 light solution
if light ic not avail able then use this solution
use 7610 -6670 ic
The Following 95 Users Say Thank You to imran zafar For This Useful Post:
Old 11-22-2010, 13:17   #2 (permalink)
Member: 328187
Thanks Meter: 1,687
1616-1280-1800 display ways
The Following 106 Users Say Thank You to imran zafar For This Useful Post:
Old 11-22-2010, 14:19   #3 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,928
nice alternative solution
ICON OF PROFESSIONALS
The Following 6 Users Say Thank You to cel_phon For This Useful Post:
Old 11-23-2010, 08:04   #4 (permalink)
Member: 1156616
Thanks Meter: 13
thnk 4 good posting;;;;
The Following 6 Users Say Thank You to CTMC For This Useful Post:
Old 11-24-2010, 12:28   #5 (permalink)
Member: 328187
Thanks Meter: 1,687
use only 3 pins of that ic*(um6k1n).....other 3 pins r not using
The Following 5 Users Say Thank You to imran zafar For This Useful Post:
Old 11-24-2010, 12:59   #6 (permalink)
fiazahmad's Avatar
Member: 263277
Thanks Meter: 142
thanks for share good job ..
The Following 2 Users Say Thank You to fiazahmad For This Useful Post:
Old 11-25-2010, 07:10   #7 (permalink)
Member: 475719
Thanks Meter: 4
waste u r time bad solucation
The Following 2 Users Say Thank You to tony_periwal For This Useful Post:
Old 11-25-2010, 10:01   #8 (permalink)
Member: 328187
Thanks Meter: 1,687
if this transistor is faulty and not available in market then
this solution can help u ??????????
The Following 2 Users Say Thank You to imran zafar For This Useful Post:
Old 11-25-2010, 10:11   #9 (permalink)
gsm_ritesh's Avatar
Member: 1396867
Thanks Meter: 48
both solution are very gud n useful.thanxxxxxxxxxxx
The Following 3 Users Say Thank You to gsm_ritesh For This Useful Post:
Old 11-27-2010, 15:44   #10 (permalink)
Member: 418682
Thanks Meter: 9
thanks brother good solution
The Following User Says Thank You to muddassar1980 For This Useful Post:
Old 11-27-2010, 18:49   #11 (permalink)
shabir97's Avatar
Member: 1277468
Sonork: 100.1603661
Thanks Meter: 701
good job thanks brother..............
br
shabir97
The Following User Says Thank You to shabir97 For This Useful Post:
Old 11-28-2010, 16:15   #12 (permalink)
Member: 888099
Thanks Meter: 33
thanks brother for the hard work. keep it up
The Following User Says Thank You to l_m_husni For This Useful Post:
Old 11-28-2010, 16:20   #13 (permalink)
richard26's Avatar
Member: 533419
Thanks Meter: 79
Nice job, thanks for sharing this useful tips..
The Following User Says Thank You to richard26 For This Useful Post:
Old 11-29-2010, 14:43   #14 (permalink)
fiazahmad's Avatar
Member: 263277
Thanks Meter: 142
not work for me i try more then 3 ic ..
The Following User Says Thank You to fiazahmad For This Useful Post:
Old 11-30-2010, 06:12   #15 (permalink)
Member: 328187
Thanks Meter: 1,687
check key pad led and lcd leds.....replace boosting coil ....check tracks
if all ok then rehot cpu......this solution must work if only transistor is faulty
1st how much voltage producing on diode kathode side????
2nd how much leds in ur lcd???? post repy
The Following 4 Users Say Thank You to imran zafar For This Useful Post:
Page generated in 0.29019 seconds with 11 queries
