08-22-2008, 13:02 | #1 (permalink) |
Junior Member Join Date: Jun 2007
Member: 531028 Status: Offline Thanks Meter: 15 | >>Nokia 1650 charging problem<< i have a 1650 when i plug into the charger , the phone dosnt show charging..it dosnt charge at all can any one help!!!!! thanx in adavnce |
The Following 8 Users Say Thank You to SAYCOMP For This Useful Post: |
08-22-2008, 15:44 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 44
Member: 265133 Status: Offline Thanks Meter: 285 | first check the fuse and the glass ic near fuse for ground try changing fuse if faulty |
The Following 3 Users Say Thank You to murthyy For This Useful Post: |
08-22-2008, 19:56 | #5 (permalink) |
Junior Member Join Date: Oct 2007
Member: 615122 Status: Offline Thanks Meter: 8 | hi man first check phones shows not charging or does not take charge ? if show not o charging than check battery and battery connector and coil and capsistors dont forget to check capsitors back side of battery conector remove those capsitors. in other condition if not take charge than check fuse and glass ic remove glass ic follow this u can fix easily |
The Following 4 Users Say Thank You to 9mmm For This Useful Post: |
08-22-2008, 20:05 | #6 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | i have nokia 1208 first it show nothing when insert charger so i change charging base than it show not charging,i try all solutions but still not charging? |
The Following 4 Users Say Thank You to HUM For This Useful Post: |
09-25-2009, 17:13 | #13 (permalink) |
Junior Member Join Date: Aug 2009 Location: philippines
Member: 1098652 Status: Offline Sonork: neltech@cavite Thanks Meter: 15 | still u have to test every capacitors,where it stops!try using multitesters,for best results! |
The Following User Says Thank You to neltech@cavite For This Useful Post: |
12-29-2009, 17:24 | #15 (permalink) |
Freak Poster Join Date: Nov 2008 Location: INDIA THE HEAVEN Age: 43
Member: 890328 Status: Offline Thanks Meter: 50 | 1650 no indication checked fuse ,capacitor, coil & components those are ok still no indication, written good pm now the cell is charging fine .working for me,friends check this solution once......... |
The Following 4 Users Say Thank You to panchami For This Useful Post: |
>>Nokia 3110c charging problem<< | SAYCOMP | Nokia Hardware & Hardware Repair | 8 | 06-21-2012 09:39 |
>>Nokia 7610 Bluetooth Problem<< | thoyyu | n-Box | 16 | 09-09-2010 04:09 |
>>Nokia 6270 Buzzer Problem<< | thoyyu | Nokia Hardware & Hardware Repair | 1 | 09-22-2008 14:03 |
>>K300i charging problem<< | thoyyu | Sony Ericsson Hardware Repair | 7 | 06-27-2008 11:50 |
>>Nokia 8250 Keypad Problem<< | thoyyu | Nokia Hardware & Hardware Repair | 2 | 09-05-2006 11:10 |
