10-09-2010, 11:48 | #3 (permalink) |
Junior Member Join Date: Oct 2007
Member: 616375 Status: Offline Thanks Meter: 0 | JAF version 1.98.62 Detected PKEY: 9001A572 Card life counter: 31.80% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 20416, Library version: 30118 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.29.0 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 03.70 14-04-09 RH-122 (c) Nokia HW version: 1500 PCI version: UEM version: 1328 UPP version: 8851 RFIC version: 0700 DSP version: ICPR81_09w10_UPP LCD version: WIN:BOHAIv91 NT39121 PPM version: V 03.70 14-04-09 RH-122 (c) Nokia AD ADSP SW version: V 03.70\n14-04-09\nRH-122\n(c) NMP\nad Production serial number: ILO413856 Product code: Module code: 0204078 Basic production code: 0568809 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 355205031675990 IMEI spare to net: 3A 55 02 05 13 76 95 09 IMEI SV to net: 33 55 02 05 13 76 95 29 F5 Master Code: 3765603716 Failed reading simlock data... Phone type: RH-122, Software version: 03.70, Language Pack: AD User code: ÿ# Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-122.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-122\ Searching for default location of ini... Checking path: \Products\RH-122\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-122\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Checking path: C:\Program Files\Nokia\Phoenix\Products\\ Searching for default location of ini... Checking path: \Products\\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\DOCUDECO\docudeco\rh1120\rh112_004.030 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\DOCUDECO\docudeco\rh1120\rh112_004.030 PPM Flash file: C:\DOCUDECO\docudeco\rh1120\rh1120_nai04.03ad CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: C:\DOCUDECO\docudeco\rh1120\rh112_004.030 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\DOCUDECO\docudeco\rh1120\rh112_004.030 PPM Flash file: C:\DOCUDECO\docudeco\rh1120\rh112_004.03ad CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\DOCUDECO\docudeco\rh1120\rh112_004.030 PPM Flash file: C:\DOCUDECO\docudeco\rh1120\rh112_004.03ad CNT Flash file: C:\DOCUDECO\docudeco\rh1120\rh1120_nai04.03ad ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Reading IMEI data... IMEI data corrupt... Failed to backup imei... MCU: C:\DOCUDECO\docudeco\rh1120\rh112_004.030 Booting phone... MCU ID: 0x2293 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14 Flash ID is 0xC0882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B38; Loader chk: 47 Loader is ready... P-key nokia module version 01.02 MSID: 84F62063CBD077DAF7C5F1D8DB MSID decoded: 3E4EBAE90047ED2FA9000000 FAID: E4FE7E27A0224A2BE5B45AFB Operation took 0 minutes 10 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 48 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 17 seconds... Restarting MCU... PPM: C:\DOCUDECO\docudeco\rh1120\rh112_004.03ad Booting phone... MCU ID: 0x2293 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14 Flash ID is 0xC0882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B38; Loader chk: 47 Loader is ready... P-key nokia module version 01.02 MSID: 84CFE2A90D6DDD8C82F1D704BD MSID decoded: 3E4EBAE90047ED2FAA000000 FAID: 459D992943F455502D10B2CE Operation took 0 minutes 11 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01240000 - 0124FFFF... Erasing area: 01250000 - 0137FFFF... Operation took 0 minutes 15 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 7 seconds... Restarting MCU... CNT: C:\DOCUDECO\docudeco\rh1120\rh1120_nai04.03ad Booting phone... MCU ID: 0x2293 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14 Flash ID is 0xC0882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B38; Loader chk: 47 Loader is ready... P-key nokia module version 01.02 MSID: 84F62063CBD077DAF7C5F1D8DB MSID decoded: 3E4EBAE90047ED2FA9000000 FAID: E4FE7E27A0224A2BE5B45AFB Operation took 0 minutes 9 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01380000 - 013AFFFF... Operation took 0 minutes 3 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 1 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Flashing Done! Operation took 2 minutes 12 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-112, Software version: 04.03 IMEI: 355205031675990 Product Code: Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 4 seconds... Done! Done! Done! |
