05-31-2013, 08:05 | #1 (permalink) |
Registered User Join Date: Jan 2008
Member: 692932 Status: Offline Sonork: +8801716503593 Thanks Meter: 25 | c2-05 security code |
05-31-2013, 08:34 | #3 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: E a r T h
Member: 216094 Status: Offline Thanks Meter: 321 | Quote:
then u recover ur handset.BUT BE CAREFUL WHEN U REHOT FLASH IC | |
05-31-2013, 09:11 | #5 (permalink) |
Member: 692932 Status: Offline Sonork: +8801716503593 Thanks Meter: 25 | c2-05 security code [QUOTE=naushad09;9465970]bro first rehot ur flash ic then try to flash again then u recover ur handset.BUT BE CAREFUL WHEN U REHOT FLASH IC i also try this method here is log: A1B5CCE8 registered to: CycloneBox Connect phone on selected interface... Core : v1.51 , FlashEngine : v1.8 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm724__08.60c.mcusw PPM : rm724__08.60c.ppm_ea CNT : rm724__08.60c.image_ea_pink_059J892 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 353285053245940 PCcode : 059J898 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\Documents and Settings\limon\Desktop\Infinity Best\Backup\Cert\353285053245940_2nd_XG213_CRT.rpl ===Flashing [MCU]=== File : rm724__08.60c.mcusw Image : rm724__08.60c.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x018C0000 Erasing, wait ... Erase done, time : 00:01:13 Write , Start : 0x40280000 , Len : 0x01840000 Flashing , wait ... Region flash error Looks like connection lost... Error... Last edited by jashiblimon; 05-31-2013 at 09:19. Reason: log |
