Old 01-27-2011, 13:18   #1 (permalink)
Member: 430612
Thanks Meter: 301
5130c show nokia then off or white screen 100% solution
who will share how to repair this problem,some i know it software and they came right after flash and some even you use all the box in the market they dont came right
sotution tested and 100% failed
1.remove bt ic
2.remove mmc ic
3.reball avilma
4.try water damage
guys let came together and fix this problem and still dnt came right it means Nokia it making fake phones now,coz even 6730c it only vibrate and cnt be fix
The Following User Says Thank You to luyanda For This Useful Post:
Old 01-27-2011, 13:21   #2 (permalink)
s.s.s.s.'s Avatar
Member: 988641
Sonork: sanjay chaudhary
Thanks Meter: 342
in 70% causes i solved this problem by remove camera ...................................
The Following User Says Thank You to s.s.s.s. For This Useful Post:
Old 01-28-2011, 07:41   #3 (permalink)
rakib_sheak's Avatar
Member: 1201843
Thanks Meter: 487
1.remove bt ic
2.remove mmc ic
3.reball avilma
4.try water damage
100 % tested
no work tested me ............
Old 01-28-2011, 08:14   #4 (permalink)
sathvik71052's Avatar
Member: 549926
Thanks Meter: 118
its waste time its 100 percent simlock problem no solution for sl3 simlock repair.........wait for some time ihave 8 sets pending.....
Old 01-29-2011, 07:58   #5 (permalink)
Member: 430612
Thanks Meter: 301
but dont say it wasted we need this phones to be repaired and we need money guys
Old 01-29-2011, 09:44   #6 (permalink)
shivashakthi's Avatar
Member: 594753
Sonork: 100.1605626
Thanks Meter: 822
1.remove bt ic
2.remove mmc ic
3.reball avilma
4.try water damage
yes i will try 110% not sould ......
Old 08-13-2011, 16:02   #7 (permalink)
Crazy Poster
Member: 1471235
Sonork: 100.1656055
Thanks Meter: 4
i make many nokia 5130
some changes bt ic memory ic and change avilma
bt guys we cant receve same probs
try one by one and make ur phones
Old 08-13-2011, 16:06   #8 (permalink)
kathirmobiles's Avatar
Member: 1591177
Thanks Meter: 85
1.remove bt ic
2.remove mmc ic
3.reball avilma
4.try water damage
not work brother try
Old 08-13-2011, 16:21   #9 (permalink)
sahilfency's Avatar
Member: 1212231
Sonork: 100.1611130
Thanks Meter: 164
yes first conform wher is problem , if u not test it ? so chack affter flesh factoryset ok or no if ok but stiil so remove camera & hands free ic & finely change bitty ic
if not work factory set so first clean & rehot full pcb ( bitty & AVILMA ) if same so dont vest u r time 100% tested combo rehot finly change it
The Following User Says Thank You to sahilfency For This Useful Post:
Old 08-13-2011, 16:58   #10 (permalink)
saiftc2's Avatar
Member: 231662
Sonork: 1607488
Thanks Meter: 390
i think problem in (sl3 simlock)..
Old 08-13-2011, 17:34   #11 (permalink)
Member: 176003
Sonork: bb pin 27883543
Thanks Meter: 74
this problem is obvios a hardware issue,possibly the same issue the nokia 1100 had where the phone switches off after 30 seconds,i think its the flasher ic wich is faulty
Old 08-19-2011, 23:34   #12 (permalink)
Member: 320894
Thanks Meter: 7
i think problem in Earpiece
Old 08-20-2011, 08:06   #13 (permalink)
Member: 430612
Thanks Meter: 301
this is intrested and you have the point,we need to learn the problem then will find solution.
Old 10-24-2011, 07:59   #14 (permalink)
Member: 972704
Sonork: zainoolzen
Thanks Meter: 20
5130c nokia then off or white screen flash via usb on mxkey,sucess for me
Old 03-14-2012, 09:34   #15 (permalink)
Member: 1661203
Sonork: 1607954
try flash 7.97 version
Page generated in 0.31979 seconds with 9 queries
