Old 02-18-2011, 18:46   #1 (permalink)
Member: 1456404
Sonork: W. App +919786579444
Thanks Meter: 526
5130,2700c all keypad not work hot solution 100%
in some 5130c,2700c,2690 all buttons are not work except power button...
Even after replacing keypad ic it would not work....
Dont need to replace keypad ics. Just rehot avilma and betty.....
All button will be working fine now 100%
post the results.
If u like my post press
thanks.........
The Following 6 Users Say Thank You to Service WorldŽ For This Useful Post:
Old 02-18-2011, 19:00   #2 (permalink)
Member: 1456404
Thanks Meter: 526
Im telling about all keypad not work . Not some buttons not work
pls read the post clearly then reply brother......
Old 02-18-2011, 19:17   #3 (permalink)
jadusumon's Avatar
Member: 1251770
Thanks Meter: 142
your idea is wrong !!!!!!!!!!!!!!!!!
Old 02-18-2011, 19:43   #4 (permalink)
Member: 1456404
Thanks Meter: 526
Its a tested solution..........
Pls check and post results....
Old 02-18-2011, 19:43   #5 (permalink)
Member: 1442683
Sonork: Vidya Mobie
7230 battari canecatr gamafar
Old 02-18-2011, 19:47   #6 (permalink)
Member: 1456404
Thanks Meter: 526
Mr pappu noida pls post in english
Old 02-18-2011, 19:48   #7 (permalink)
jadusumon's Avatar
Member: 1251770
Thanks Meter: 142
may be fortunately you are success but it,s not real solution
Old 02-18-2011, 19:52   #8 (permalink)
Member: 1456404
Thanks Meter: 526
I try it on 7 handsets after replaced keypad ics it would not work
i removed side volume buttons still not work..
After rehot the betty and avilma it will be done.........
The Following User Says Thank You to Service WorldŽ For This Useful Post:
Old 03-17-2011, 23:45   #9 (permalink)
Member: 601591
Thanks Meter: 86
is not work for me at all. the best solution is remove all the switch botton
one of them is freezing the set you can remove them one by one
& test your phone this is the best solution 10000000000000%
dont forget to say thanks
Old 03-18-2011, 00:01   #10 (permalink)
Member: 747260
Sonork: 100.1606177
Thanks Meter: 45
i agree with this one remove the switch one by one and you will fine the answer
Old 03-18-2011, 07:03   #11 (permalink)
Member: 1480973
Thanks Meter: 25
sir plz give me betty and avilma ic pictur
I have on idia betty and avilma ic
Old 03-18-2011, 07:13   #12 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,687
here is working solution
http://forum.gsmhosting.com/vbb/f148...lease-1226463/
The Following User Says Thank You to imran zafar For This Useful Post:
Old 03-18-2011, 10:15   #13 (permalink)
praji's Avatar
Member: 563648
Sonork: 100.1594523
Thanks Meter: 87
Imran,
working but after 2 days same problm,checking selftest in ufs keyboard stuck "failed".
After change front speaker,now working fine by me
Old 04-22-2011, 11:09   #14 (permalink)
Member: 145399
Thanks Meter: 26
very good post. I just rehot the both ic. now its working. thanks.
Old 04-22-2011, 12:10   #15 (permalink)
Mind Power's Avatar
Member: 338106
Thanks Meter: 55
reparing is hit and trial process so all experiences can not always be rit although it is good sharing wethere it works or not
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Page generated in 0.21370 seconds with 9 queries
