Old 07-13-2005, 15:47   #1 (permalink)
Member: 73144
Thanks Meter: 5
6610 nokia dead
Received nokia 6610 nhl4u with water damage and dead, i cleaned the pcb now i am able to flash it compleately. after flashing itself it does not switch on still dead. i used ufs-3. when i read info it shows all details as 7210 nhl4.i flashed it trice with nhl 4-u versio file. problem remains .what to do. please help.
Old 07-13-2005, 15:58   #2 (permalink)
Member: 157106
Thanks Meter: 2
errr...... u say recieved it with water damage?? might ahve been insured for transit....see if you can get it replaced
Old 07-13-2005, 18:08   #3 (permalink)
kardelen gsm's Avatar
Member: 133173
Thanks Meter: 119
flashing is ok not power on...check attachment...solve your problem...regards
Old 07-14-2005, 08:09   #4 (permalink)
jarniel's Avatar
Member: 149600
Thanks Meter: 11
it is display local mode or did you try to put it on normal mode???if the display in normal mode is insert sim phone is good, check the power switch maybe it's not work...did you try to charge the phone after you flash or did you check the terminal if there's partially shorted???? if the prob still the same if you try all those possible prob.. try to reflow the uem&upp then post the result,thanks
Old 04-25-2006, 17:56   #5 (permalink)
Member: 225711
thanks for your attachement
i did as shown in yur attachment but when i put in the battery it display text mode.pls i need your help.
Old 04-26-2006, 03:34   #6 (permalink)
goffaman's Avatar
Member: 164237
Thanks Meter: 12
resolder battery terminal or replace resistor with 4 pins at the back of battery terminl... sorry i dont have at the moment a schematic manual
Old 04-26-2006, 10:01   #7 (permalink)
Member: 211577
Cool
hi resolde his power ic and geve to all bord heate but ram falsh ran cpu no heate try plz
Old 08-30-2006, 11:30   #8 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
it's a water damage phone, i already clean the board, i already heat the cpu and UEM, but it won't show local mode in the tornado
1st Boot Ok, DCT4, UPP: 1120
Fl0: 0x01000000-0x017FFFFF,002088BE,St M28W640
Algorithm: u_st_i.fia, Ver: 4.52.0
Algorithm Ok, MSID: 84552815859E8D84B66E9F0298
Decoded MSID: 38E9BAE9-00D5332C-A9000000
Encoded FAID: 09639F1A-21844FA0-CFBD2E04
Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00
Area2: 0x01010000-0x0157FFFF Erased, Time: 01:18
Area3: 0x016B0000-0x017EFFFF Erased, Time: 00:18
Area4: 0x01EB0000-0x01FEFFFF Out of Chip Bounds
MCU Flashing Completed, Time: 00:35
Area1: 0x01580000-0x016AFFFF Erased, Time: 00:16
CNT Flashing Completed, Time: 00:02
Extracting Contents Package ...
Init Local Mode Failed
Contents Package Extracting Failed:
Process Failed, Repowering Mobile
Please advice
Old 06-11-2007, 15:18   #9 (permalink)
ARS.Rehman's Avatar
Member: 491455
Sonork: On My LAB
Thanks Meter: 296
Fl0: 0x01000000-0x01FFFFFF,DD05D80B, UNKNOWN CHIP !
Algorithm: u_intel.fia, Ver: 4.61.0
Algorithm Ok, MSID: 84489F54AC2B61115D96E7A2FC
Decoded MSID: 82A9BAE9-00CAFD79-AA000000
Encoded FAID: FF051C4B-3E2DCAC1-BE84E157
Erasing: 0x01000000-0x0100FFFF ...
Erasing Error: 10, at: 0x01000000-0x0100FFFF, 940207, Time: 00:00
pls help
How To Cut Midi Files To 6610 Nokia gados Nokia Multimedia 4 01-02-2009 14:02
6610 i dead but flashing is ok vipul manchanda Nokia Hardware & Hardware Repair 13 08-28-2006 15:35
6610 i dead ZEBUN Nokia Hardware & Hardware Repair 6 02-21-2006 13:28
6610 nokia hanging jetawo ademola Nokia Digital Core Technology 4 ( DCT-4 ) 2 03-18-2005 14:05
Page generated in 0.23731 seconds with 10 queries
