03-23-2010, 09:01 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Kuwait Age: 44
Member: 250607 Status: Offline Thanks Meter: 42 | nokia 2330c "Contact service" PPM SW : V 06.75 29-04-09 RM-512 (c) Nokia MH Prd.Code: 0584547 Bpr.Code: 0569925 Prod.Sn : IYA124208 HW Vers : 2000 UEM : 4386 UPP : 12648 [3168] RFIC Ver: 0500 DSP Vers: ICPR72_09w08_UPP LCD Type: SUEZ IMEI : 355248-03-559513-7 SL Conf : 555-55-55555555555 SL Prof : 555555555503555-5 SL Var : 00553552480355951300 SL Aux : 000B5555 HW Sig : 4FAA487A7C06D577 Box Id : 5555555555555555 SL Data Corrupted Provider: Not Found |
03-23-2010, 09:13 | #4 (permalink) |
Member: 250607 Status: Offline Thanks Meter: 42 | 2330c Contact Service Solved By Mx Key CONFIG_DATA: 5555555555555555 PROFILE_BITS: 5555555555035555 SIMLOCK_DATA corrupted! PhoneType:RM-512 SwVersion: V 06.75 29-04-09 RM-512 (c) Nokia MCU file: rm512__06.75.mcusw Trying to find patch position ...OK, case id: 4 ROM version: 3 ASIC ID: 0x3168 u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8981 [Intel ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00CC5FE5:3B8ADA60 Area [01000000-0101FFFF] erased in 0.797 s Area [01080000-0109FFFF] erased in 0.875 s Programming ... Programming completed. Updating SIMLOCK ...OK ASIC ID: 0x3168 u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8981 [Intel ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 u3_intel.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00CC5FE5:3B8ADA60 Area [01000000-0101FFFF] erased in 0.828 s Area [01080000-0109FFFF] erased in 0.844 s Programming ... Programming completed. Completed in 1 min 9.204 s Reading Simlock info ... Imei net: 35524803559513 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
nokia 3310 "Contact Service" | InGyneer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 07-25-2003 15:45 |
Nokia 3410 "Contact service".where 2 get full fls+eeprom ? | the_frightener | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-12-2003 18:34 |
Nokia 7110 - "Contact Service"- problem | nicos | Nokia Hardware & Hardware Repair | 5 | 02-09-2003 13:35 |
Nokia 8810 "Contact Service", can't solved by re-solder EEprom, Flash & Ram. | Ken-mkII | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 05-24-2002 06:26 |
Nokia 8250 "Contact service" | Danchik | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-30-2001 15:25 |
