10-13-2009, 05:01 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: INDIA(GUJRAT,RAJKOT) Age: 37
Member: 397884 Status: Offline Sonork: 100.1587035 Thanks Meter: 168 | nokia 2600c & 2630 keyped problem i have nokia 2600 & 2630 pcs witch have problem keypad not working 1) i change keypad strip 2) i change keypad ic(og from working 2626 ) 3) i reball cpu 4) check all track between ic to keypad socket all is ok but no work keypad and i also make self test it show keypad stuck = failed i cant understand where is problem i try all thing but no result please help me for solving this problem thanking you Patel telecom |
The Following User Says Thank You to .::PATEL TELECOM::. For This Useful Post: |
10-13-2009, 09:02 | #6 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Philippines davao
Member: 216690 Status: Offline Thanks Meter: 53 | if the buttons cant executed. use two finger method need two hands to operate the phone heres is the simple trick 1 GO TO hold press GO TO then MENU (middle) 2 BACK or CANCEL hold press BACK or CANCEL then CALL BUTTON (color green) 3 UP BUTTON hold press UP BUTTON then RIGHT BUTTON 4 DOWN BUTTON hold press DOWN BUTTON then RIGHT BUTTON BTW THE ONLY SOLUTION TO FIX THIS PROBLEM IS..... REPLACE UPP..... thanks for reading..... |
The Following 5 Users Say Thank You to airchiew For This Useful Post: |
10-14-2009, 08:50 | #10 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Mobile solution at Pak_Lahore Age: 46
Member: 158032 Status: Offline Thanks Meter: 331 | Bro if u like the post then only press thanks button that's all... |
The Following User Says Thank You to ..::My3gtech::.. For This Useful Post: |
10-14-2009, 09:39 | #11 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Port Harcourt Nigeria Age: 51
Member: 197720 Status: Offline Thanks Meter: 24 | i have two pieces few days ago i tried everything i could refused to work have to soak it in petrol for one day then dried under 200 watt bulb the two are now functional |
10-14-2009, 09:43 | #12 (permalink) | |
Member: 397884 Status: Offline Sonork: 100.1587035 Thanks Meter: 168 | Quote:
ha ha ha very funny trick u change ic,socket etc???????? but same problem ??? than put in petrol???? ok thanks for give trick thank you very much | |
nokia 2600c and 2630 files | ashaka | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 06-18-2008 04:53 |
How to unlock Nokia 2760 & 2630 | brijmehta1 | MT-BOX | 9 | 05-27-2008 09:57 |
New Nokia 1650 & 2630 Mobile MB Here | R@ZIB-BD | Java, iOS, Android, Symbian development | 6 | 04-22-2008 18:42 |
New Products: Nokia 6267 & 2630 Jaf Cable; Archer Sam Clip;Samsung E210 unibox cable. | Tele-way | Main Sales Section | 0 | 09-21-2007 10:04 |
