01-04-2010, 06:15 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: KOLKATA Age: 51
Member: 102582 Status: Offline Thanks Meter: 72 | Nokia 2600C Classic Automatic On & Keypad Problem... Pls. help me in Nokia 2600C classic phone automatically getting swtiched on when I insert the battery. Keypad also not working. Even not being switched on after pressing the power on button. I have done the following things but not solved : 1. Changed the keypad ic twice. 2. Reballed the UEM. 3. Flashed it completely using the latest file version. 4. Resold the CPU i.e. heat up with AMTECH GEL. 5. Washed it thoroughly with thineer and IPA twice or thrice. What rest you can suggest me? Thanks in advance, Regards, amit123 |
01-04-2010, 06:33 | #3 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Bangladesh Age: 38
Member: 1003058 Status: Offline Sonork: 100.1589274/mahbubalfa Thanks Meter: 26,433 | Quote:
result post here. | |
01-04-2010, 06:36 | #4 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Talk to *** and He Will Listen
Member: 532761 Status: Offline Sonork: 100-1592994 Thanks Meter: 1,104 | Quote:
due to complicated fualt. | |
The Following User Says Thank You to venuno For This Useful Post: |
01-04-2010, 06:50 | #5 (permalink) |
Member: 102582 Status: Offline Thanks Meter: 72 | Thanks for ur reply. Yes, I changed the Keypad Flex with a good one but no joy for me so far. Can it be the RTC Problem? Thanks, Regards, amit123 |
The Following User Says Thank You to amit123 For This Useful Post: |
nokia 2600c No power on after unlock [ Solved, thanks alkhaleejmobile ] | defcon2 | Cyclonebox | 2 | 03-13-2010 11:45 |
Nokia 2600c No graphics on lcd | dey mobiles | Nokia Hardware & Hardware Repair | 0 | 10-07-2009 11:09 |
c140 AUTO ON & KEYPAD NOT WORK | romajess | Samsung Hardware Repair | 0 | 09-10-2009 15:04 |
Headset & keypad Problem in one exe | shivashakthi | Nokia Hardware & Hardware Repair | 0 | 03-14-2009 09:49 |
Oxygen Phone Manager II for Nokia Fones Disconnects Automaticly on BlueTooth | Sor3l | Nokia Hardware & Hardware Repair | 1 | 01-27-2006 23:46 |
