Nokia 2626 charger not supported if i connect charger to my nokia 2626, it displays the message "charger not supported".pls can somebody help with the solution to this problem.Thanks in advance. |
1 Attachment(s) try this brother BR vinay_sharma |
thanks a lot bro, i will try it now and post the result to back |
write good pm thise problem slove |
First,Change battery & connect orignal charger not ok ,then check Hardware, |
bro. just check the battery terminal and the battery itself or may you are using the bl-5a batery coz it wont work in that phone , just try use bl-5c |
A LOT of Thx.................. |
thanx a lot to try to help us but all r fake nothing to work plz post its corect sulation |
bro, maybe that phone is using a battery BL-5CA coz if you try to charge it i will appear charger not supported, just try to use BL-5C only and try again to charge the phone..... *** bless!! |
2626 charger not supported Quote:
Daanish |
Nokia 2626 charger not suported |
first chack r22 1 remove r22 one point is grnd chack and then post |
1000 % working thanks |
