Old 10-06-2010, 02:54   #1 (permalink)
Member: 828494
Sonork: kruger selection
Thanks Meter: 18
7210c vibrates and will not power on
plsss guys, 7210 when powered on will only vibrate and show nokia without background light. i flash the phone with different versions even with ver7.23 still the same, also 5310 even after flashing too will show nokia then fade into blue screen so what will i do sirs. thanks
Old 10-06-2010, 03:52   #2 (permalink)
jaymercado48's Avatar
Member: 1382153
Sonork: 100.1594354
Thanks Meter: 60
rehot the power ic brother.......
Old 10-06-2010, 05:48   #3 (permalink)
Member: 828494
Thanks Meter: 18
any more solution
guys, plss is there more ideas or solution for this problem.thanks
Old 10-06-2010, 05:51   #4 (permalink)
Imrankhan's Avatar
Member: 573962
Sonork: 100.1603021
Thanks Meter: 480
rehot power ic and clean pcb
Old 10-06-2010, 06:05   #5 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
remove cemra and try again
Old 10-06-2010, 07:47   #6 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,687
dear remove lcd clean lcd jeck both of sides
how much consumption of ur set in standby mode???
Old 03-13-2011, 15:44   #7 (permalink)
pallumobile's Avatar
Member: 659890
Thanks Meter: 263
Great job The trick works for me.
Old 05-13-2011, 20:45   #8 (permalink)
Member: 1228162
yes .., tricks is 1000% working.,
Old 06-02-2011, 12:44   #9 (permalink)
Member: 1156501
Thanks Meter: 15
good job bro keep it up ...................trick is 10000000000000000000%work
Old 03-09-2013, 07:56   #10 (permalink)
Member: 1287160
thank you sir for your very useful post
this is really a great solution........
1000000% working....thanks........
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.17447 seconds with 9 queries
