Old 03-03-2009, 14:55   #1 (permalink)
Member: 296003
Thanks Meter: 5
3600s contec sarvice
3600s is water demeg, now i fleshing with jaf (usb) Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
Elf2flash 07.40.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting.......................................... ..................................Loader Sent!
Stage 3 starting..................Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 2379, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-352\rm352__05.20.mcusw...
Erasing cmt zone 00000000 - 000006BF ... Erase result: 0000
Erasing cmt zone 000006C0 - 0001FFFF ... Erase result: 0000
Erasing cmt zone 00040000 - 000BFFFF ... Erase result: 0000
Erasing cmt zone 000C0000 - 0013FFFF ... Erase result: 0000
Erasing cmt zone 00140000 - 014DFFFF ... Erase result: 0000
Erasing cmt zone 014E0000 - 0167FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-352\rm352__05.20.ppm_mr...
Erasing cmt zone 01680000 - 01F1FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-352\rm352__05.20.image_mr_in_charcoal...
Erasing cmt zone 01F20000 - 022BFFFF ... Erase result: 0000
Erasing cmt zone 022C0000 - 03FBFFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for NOLO
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
Sending CMT HASH for UPDAPP
Sending CMT HASH for DSP0
Sending CMT HASH for MCUSW
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
MCUSW: V 05.20
15-10-08
RM-352
(c) Nokia
APESW: (null)
VariantSW: (null)
Prodcode: 0561197
DCT4/BB5 counter: 212
Done!
but remove usb cable and battory then insert battory and power on 'contec sarvice'
plz help
Old 03-03-2009, 18:32   #2 (permalink)
masum_sohel's Avatar
Member: 852543
Thanks Meter: 2,338
check the imei.if imei is 1234567890 u need rpl for this phone
The Following 2 Users Say Thank You to masum_sohel For This Useful Post:
Old 03-03-2009, 18:56   #3 (permalink)
Member: 478116
Thanks Meter: 11
Check Energy Managment - EMC
Old 03-04-2009, 06:32   #4 (permalink)
Member: 296003
Thanks Meter: 5
3600s
PRESS POWER ON NOW!
Using 06.02.002
Elf2flash 07.40.000
CMT RAW loader...
Status byte: 8000
Result: 0000
Erasing cmt...
Send CMT CFG...
Writing cmt...
Rebooting...
Restarting CMT...
Pooling phone...
MCUSW: V 05.20
15-10-08
RM-352
(c) Nokia
APESW: (null)
VariantSW: (null)
Prodcode: 0561197
Done!
plz help
Old 03-04-2009, 06:35   #5 (permalink)
Miftah_Lutfi's Avatar
Member: 638396
Sonork: 100.1615405
Thanks Meter: 170
Please share info & self test logs...,
Old 03-04-2009, 06:43   #6 (permalink)
Member: 296003
Thanks Meter: 5
sir, i have no fbus cable so i not chek self test.................
Old 03-04-2009, 06:54   #7 (permalink)
Member: 296003
Thanks Meter: 5
sir, info is here
Searching for phone...Detected P-KEY: 90003307
P-key nokia module version 01.02
Found
MCU SW version: V 05.20
15-10-08
RM-352
(c) Nokia
HW version: 1001
PCI version:
RFIC version:  064c0601
DSP version:
ICPR72_08w37
LCD version: SEIKO
PPM version: V 05.20
15-10-08
RM-352
(c) Nokia
MR
BT MCM version: 2222-143C
Retu version: 15
Tahvo version: 22
Content Pack version: Content: mr_in_charcoal
V 05.20
15-10-08
RM-352
(c) Nokia
Production serial number: DKJ607920
Product code: 0561197
Module code: 0203624
Basic production code: 0551468
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 355706027242471
IMEI spare to net: 3A 55 07 06 72 42 42 07
IMEI SV to net: 33 55 07 06 72 42 42 17 F9
LOCK STATUS:
CONFIG KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Loading INI list...
Reading product code...
Product Code: 0561197
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-352\
Searching for default location of ini...
Checking path: \Products\RM-352\
Scanning ini files...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-352\rm352__05.20.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-352\rm352__05.20.ppm_mr
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-352\rm352__05.20.image_mr_in_charcoal
APE Variant file: NONE
Languages in ppm: English,French,Portuguese
Done!
Old 03-04-2009, 07:10   #8 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
@BRKATHAVADIA
U HAVE TO USE SX4 AUTH AND WRITE MODIFIED PM WITHOUT 308
AND ALL WILL BE OK
WBR
sahil2000ind
Old 03-04-2009, 07:32   #9 (permalink)
Member: 296003
Thanks Meter: 5
where is EMC plz send imeg
Old 03-04-2009, 07:34   #10 (permalink)
Member: 296003
Thanks Meter: 5
Originally Posted by sahil2000ind View Post
@BRKATHAVADIA
AND ALL WILL BE OK
WBR
sahil2000ind
sir, i have not 3600s pm
Old 03-04-2009, 13:41   #11 (permalink)
Member: 638396
Sonork: 100.1615405
Thanks Meter: 170
Bro.., before do anything.., u must do self test..,
that mean u must use fbus cable.., u can buy it..,
then share selftest logs here...,
it can be caused by hw or sw problem.., so to ensure.., u must do selftest..,
br..,
The Following User Says Thank You to Miftah_Lutfi For This Useful Post:
need pinout sigmatel fxd 3600 bassemzini Infinity-Box 0 03-29-2010 19:22
3600s contec sarvice BRKATHAVADIA Nokia Hardware & Hardware Repair 0 03-04-2009 06:36
N-72 Phone Start Up Failed Contec The Retailer bharatg Nokia Hardware & Hardware Repair 0 01-17-2008 06:37
7250i contec service after flashing with griffin SATISH Griffin 10 04-22-2004 23:13
contec service sw baraka42 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 10-12-2002 17:18
Page generated in 0.27360 seconds with 9 queries
