08-24-2009, 02:29 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | 7610 nokia hung up software is okey here is complet flush in UB BOXE. CU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Input power: 13.58V OK. Hardware ID: 1081 Boot Loader: w3_2nd.fia 4 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] Max Flash Devices: 4 Flash ID 1: 00ECDDFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 00 SectorSize: 0x010000 Flash ID 2: 00ECEEFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 02 SectorSize: 0x010000 Flash ID 3: 00EC2250 - 0000 Rev: 0121 Manufacturer: Samsung MSB: 04 SectorSize: 0x010000 Flash ID 4: 00000001 - 0000 Rev: 0000 Manufacturer: Unused MSB: 06 SectorSize: 0x000001 Signature: C60000EA750100EA780100EA7B0100EA Flash Loader: w3_amd.fia 32 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] ASIC Type: 5 MSID: 84-80F9AB82FFD8D6EC3AD8AC5B CobbaID: 008D6F4D; 2984DA7E FAID: D2D5E50EB3DBDE29DD5D1790 Erase time: 3:05,5 sec. Flashing MCU file: RH51_52_67_68PE706420.C1 Flash time: 4:34,6 sec. After MCU Flash Delay: 5000 msec. Input power: 13.54V OK. Hardware ID: 1081 Boot Loader: w3_2nd.fia 4 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] Max Flash Devices: 4 Flash ID 1: 00ECDDFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 00 SectorSize: 0x010000 Flash ID 2: 00ECEEFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 02 SectorSize: 0x010000 Flash ID 3: 00EC2250 - 0000 Rev: 0121 Manufacturer: Samsung MSB: 04 SectorSize: 0x010000 Flash ID 4: 00000001 - 0000 Rev: 0000 Manufacturer: Unused MSB: 06 SectorSize: 0x000001 Signature: C60000EA750100EA780100EA7B0100EA Flash Loader: w3_amd.fia 32 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] MSID: 84-80F9AB82FFD8D6EC3AD8AC5B CobbaID: 008D6F4D; 2984DA7E FAID: D2D5E50EB3DBDE29DD5D1790 Erase time: 20,4 sec. Flashing PPM file: RH51PE706420.02 Flash time: 30,1 sec. Total time: 9:14,10 sec. After Flash Delay: 15000 msec. Initializing phone... Output power at Line1 3.95V is in range of: 4.00V ±10.0% Phone powered. Set Defaults Timeout: 250 sec. Setting defaults (it can take a minunte, or more)... Set defaults time: 58,6 sec. Reading Info... MCU Version: V 7.0642.0 Date: 18-10-06 Type: RH-51 (7610) Additional_1: (c)NMP [Nokia 7610 CABLE 7610] PPM Version: V 7.0642.0 Date: 18-10-06 Type: RH-51 (7610) Pack: (c)NMP.02 Product code: 0514537 Production serial: PEN974429 Hardware version: 7033 Security code: 12345 Original IMEI: 354844-01-******** IMEI: 354844-01-******** Asic type: 5 Profile bits: 0000000000000005 Lockinfo: 0010100000000000 Lock version: 0 SIMLock service: SIMLOCKLIB VERSION 2.29 [04090004010C] Writing PP file... -------------------------------------------------------------------------------- TDCT4FlashPhoneThread 2.7.8.2174 finished at: 2009/08/23 19:57:31 Done. TDCT4ChangeModeThread 2.7.8.2174 started at: 2009/08/23 19:57:40 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Switching from Local to Normal mode... N-Local mode set. -------------------------------------------------------------------------------- TDCT4ChangeModeThread 2.7.8.2174 finished at: 2009/08/23 19:57:50 Done. WD2 BT2 [WD2 ALGORITHM] MCU File: RH51_52PE404214.C1 25 579 kB MSB: [00, 02] Speed: [100k, 333k, 6500k, 51k] Baud. Supported Hardwares: [0082, 1081] WD2 BT2 [WD2 ALGORITHM] PPM File: RH51PE404214.01 1 994 kB Languages: English, German, French (France) MSB: [00, 02] Speed: [100k, 333k, 6500k, 51k] Baud. Supported Hardwares: [0082, 1081] TDCT4FlashPhoneThread 2.7.8.2174 started at: 2009/08/23 19:59:10 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Input power: 13.56V OK. Hardware ID: 1081 Boot Loader: w3_2nd.fia 4 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] Max Flash Devices: 4 Flash ID 1: 00ECDDFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 00 SectorSize: 0x010000 Flash ID 2: 00ECEEFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 02 SectorSize: 0x010000 Flash ID 3: 00EC2250 - 0000 Rev: 0121 Manufacturer: Samsung MSB: 04 SectorSize: 0x010000 Flash ID 4: 00000001 - 0000 Rev: 0000 Manufacturer: Unused MSB: 06 SectorSize: 0x000001 Signature: C60000EA750100EA780100EA7B0100EA Flash Loader: w3_amd.fia 32 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] ASIC Type: 5 MSID: 84-9FFDE5ECEED5E6863A8E28CA CobbaID: 008D6F4D; 2984DA7E FAID: C9EA14EF0041D23A5C84231A Erase time: 3:08,8 sec. Flashing MCU file: RH51_52PE404214.C1 Flash time: 4:38,7 sec. After MCU Flash Delay: 5000 msec. Input power: 13.68V OK. Hardware ID: 1081 Boot Loader: w3_2nd.fia 4 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] Input power: 13.68V OK. Hardware ID: 1081 Boot Loader: w3_2nd.fia 4 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] Max Flash Devices: 4 Flash ID 1: 00ECDDFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 00 SectorSize: 0x010000 Flash ID 2: 00ECEEFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 02 SectorSize: 0x010000 Flash ID 3: 00EC2250 - 0000 Rev: 0121 Manufacturer: Samsung MSB: 04 SectorSize: 0x010000 Flash ID 4: 00000001 - 0000 Rev: 0000 Manufacturer: Unused MSB: 06 SectorSize: 0x000001 Signature: C60000EA750100EA780100EA7B0100EA Flash Loader: w3_amd.fia 32 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] MSID: 84-CD3B70E36DEF0BA6D1E8B382 CobbaID: 008D6F4D; 2984DA7E FAID: DFC25868F863CF330CECD5C4 Erase time: 15,8 sec. Flashing PPM file: RH51PE404214.01 Flash time: 21,9 sec. Total time: 9:16,2 sec. After Flash Delay: 15000 msec. Initializing phone... Output power at Line1 3.97V is in range of: 4.00V ±10.0% Initializing phone... Output power at Line1 3.97V is in range of: 4.00V ±10.0% -------------------------------------------------------------------------------- TDCT4FlashPhoneThread 2.7.8.2174 finished at: 2009/08/23 20:09:46 Aborted by user. MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBCTKJD2] DCT4 PP File: euroals.pp 13 elements. WD2 BT2 [WD2 ALGORITHM] PPM File: RH51PE505090.30 3 444 kB Languages: English, Hong Kong (Use MCU C2) MSB: [00, 02] Speed: [100k, 333k, 6500k, 51k] Baud. Supported Hardwares: [0082, 1081] WD2 BT2 [WD2 ALGORITHM] MCU File: RH51_67PE505090.C2 26 596 kB MSB: [00, 02] Speed: [100k, 333k, 6500k, 51k] Baud. Supported Hardwares: [0082, 1081] TDCT4FlashPhoneThread 2.7.8.2174 started at: 2009/08/23 20:10:18 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Input power: 13.64V OK. Hardware ID: 1081 Boot Loader: w3_2nd.fia 4 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] Max Flash Devices: 4 Flash ID 1: 00ECDDFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 00 SectorSize: 0x010000 Flash ID 2: 00ECEEFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 02 SectorSize: 0x010000 Flash ID 3: 00EC2250 - 0000 Rev: 0121 Manufacturer: Samsung MSB: 04 SectorSize: 0x010000 Flash ID 4: 00000001 - 0000 Rev: 0000 Manufacturer: Unused MSB: 06 SectorSize: 0x000001 Signature: C60000EA750100EA780100EA7B0100EA Flash Loader: w3_amd.fia 32 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] ASIC Type: 5 MSID: 84-80F9AB82FFD8D6EC3AD8AC5B CobbaID: 008D6F4D; 2984DA7E FAID: D2D5E50EB3DBDE29DD5D1790 Erase time: 3:15,9 sec. Flashing MCU file: RH51_67PE505090.C2 Flash time: 4:46,4 sec. After MCU Flash Delay: 5000 msec. Input power: 13.66V OK. Hardware ID: 1081 Boot Loader: w3_2nd.fia 4 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] Max Flash Devices: 4 Flash ID 1: 00ECDDFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 00 SectorSize: 0x010000 Flash ID 2: 00ECEEFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 02 SectorSize: 0x010000 Flash ID 3: 00EC2250 - 0000 Rev: 0121 Manufacturer: Samsung MSB: 04 SectorSize: 0x010000 Flash ID 4: 00000001 - 0000 Rev: 0000 Manufacturer: Unused MSB: 06 SectorSize: 0x000001 Signature: C60000EA750100EA780100EA7B0100EA Flash Loader: w3_amd.fia 32 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] MSID: 84-CD3B70E36DEF0BA6D1E8B382 CobbaID: 008D6F4D; 2984DA7E FAID: DFC25868F863CF330CECD5C4 Erase time: 26,2 sec. Flashing PPM file: RH51PE505090.30 Flash time: 37,6 sec. Total time: 9:46,5 sec. After Flash Delay: 15000 msec. Initializing phone... Output power at Line1 3.97V is in range of: 4.00V ±10.0% Initializing phone... Output power at Line1 3.97V is in range of: 4.00V ±10.0% Aborting process... -------------------------------------------------------------------------------- TDCT4FlashPhoneThread 2.7.8.2174 finished at: 2009/08/23 20:24:27 Aborted by user. MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Device opened at USB->Universal Box [UBCTKJD2] TRefreshFileListThread 2.7.8.2174 started at: 2009/08/23 20:24:45 -------------------------------------------------------------------------------- MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Connecting to server: US1 Receiving file list... Decompressing... Generating file list... Refreshing list... -------------------------------------------------------------------------------- TRefreshFileListThread 2.7.8.2174 finished at: 2009/08/23 20:35:16 Done. TDownloadFileListThread 2.7.8.2174 started at: 2009/08/23 20:35:53 -------------------------------------------------------------------------------- MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Connecting to server: US1 Downloading files... Refreshing file list... -------------------------------------------------------------------------------- TDownloadFileListThread 2.7.8.2174 finished at: 2009/08/23 20:47:03 Done. WD2 BT2 [WD2 ALGORITHM] MCU File: RH51_52_67_68PE706420.C1 25 095 kB MSB: [00, 02] Speed: [100k, 333k, 6500k, 51k] Baud. Supported Hardwares: [0082, 1081] WD2 BT2 [WD2 ALGORITHM] PPM File: RH52PE706420.43 3 244 kB MSB: [00, 02] Speed: [100k, 333k, 6500k, 51k] Baud. Supported Hardwares: [0082, 1081] TDCT4FlashPhoneThread 2.7.8.2174 started at: 2009/08/23 20:48:23 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Input power: 15.06V OK. Hardware ID: 1081 Boot Loader: w3_2nd.fia 4 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] Max Flash Devices: 4 Flash ID 1: 00ECDDFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 00 SectorSize: 0x010000 Flash ID 2: 00ECEEFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 02 SectorSize: 0x010000 Flash ID 3: 00EC2250 - 0000 Rev: 0121 Manufacturer: Samsung MSB: 04 SectorSize: 0x010000 Flash ID 4: 00000001 - 0000 Rev: 0000 Manufacturer: Unused MSB: 06 SectorSize: 0x000001 Signature: C60000EA750100EA780100EA7B0100EA Flash Loader: w3_amd.fia 32 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] ASIC Type: 5 MSID: 84-80F9AB82FFD8D6EC3AD8AC5B CobbaID: 008D6F4D; 2984DA7E FAID: D2D5E50EB3DBDE29DD5D1790 Erase time: 3:05,5 sec. Flashing MCU file: RH51_52_67_68PE706420.C1 Flash time: 4:49,10 sec. After MCU Flash Delay: 5000 msec. Input power: 15.36V OK. Hardware ID: 1081 Boot Loader: w3_2nd.fia 4 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] Input power: 15.75V OK. Hardware ID: 1081 Boot Loader: w3_2nd.fia 4 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] Max Flash Devices: 4 Flash ID 1: 00ECDDFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 00 SectorSize: 0x010000 Flash ID 2: 00ECEEFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 02 SectorSize: 0x010000 Flash ID 3: 00EC2250 - 0000 Rev: 0121 Manufacturer: Samsung MSB: 04 SectorSize: 0x010000 Flash ID 4: 00000001 - 0000 Rev: 0000 Manufacturer: Unused MSB: 06 SectorSize: 0x000001 Signature: C60000EA750100EA780100EA7B0100EA Flash Loader: w3_amd.fia 32 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] MSID: 84-CD3B70E36DEF0BA6D1E8B382 CobbaID: 008D6F4D; 2984DA7E FAID: DFC25868F863CF330CECD5C4 Erase time: 24,5 sec. Flashing PPM file: RH52PE706420.43 Flash time: 35,8 sec. Total time: 17:15,1 sec. After Flash Delay: 15000 msec. Initializing phone... Output power at Line1 3.97V is in range of: 4.00V ±10.0% Phone powered. Set Defaults Timeout: 250 sec. Setting defaults (it can take a minunte, or more)... Set defaults time: 58,8 sec. Reading Info... MCU Version: V 7.0642.0 Date: 18-10-06 Type: RH-52 (7610) Additional_1: (c)NMP [Nokia 7610b CABLE 7610] PPM Version: V 7.0642.0 Date: 18-10-06 Type: RH-52 (7610) Pack: (c)NMP.43 Product code: 0514537 Production serial: PEN974429 Hardware version: 7033 Security code: 12345 Original IMEI: 354844-01-******** IMEI: 354844-01-******** Asic type: 5 Profile bits: 0000000000000005 Lockinfo: 0010100000000000 Lock version: 0 SIMLock service: SIMLOCKLIB VERSION 2.29 [04090004010C] Writing PP file... -------------------------------------------------------------------------------- TDCT4FlashPhoneThread 2.7.8.2174 finished at: 2009/08/23 21:07:17 Done. TDCT4ChangeModeThread 2.7.8.2174 started at: 2009/08/23 21:07:49 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Switching from Local to Normal mode... N-Local mode set. -------------------------------------------------------------------------------- TDCT4ChangeModeThread 2.7.8.2174 finished at: 2009/08/23 21:07:59 Done. -------------------------------------------------------------------------------- TUniversalForm 2.7.8.2174 finished at: 2009/08/23 21:09:55 TUniversalForm 2.7.8.2174 started at: 2009/08/24 09:05:43 -------------------------------------------------------------------------------- MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Authenticating software... Checking messages... Connecting to server: US1 Receiving file list... Generating file list... No new message. Device opened at USB->Universal Box [UBCTKJD2] TSelfUpdateThread 2.7.8.2174 started at: 2009/08/24 09:05:47 -------------------------------------------------------------------------------- MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. Connecting to server: US1 Receiving latest versions... All available algos are up to date. Current local filepack version: 6.01 is up to date. Current local executable version: 2.7.8.2174 is up to date. MCU Boot Version: 1.069, and up to date. SMCU Boot Version: 1.34, and up to date. -------------------------------------------------------------------------------- TSelfUpdateThread 2.7.8.2174 finished at: 2009/08/24 09:05:50 Done. DCT4 PP File: uscsp.pp 12 elements. WD2 BT2 [WD2 ALGORITHM] PPM File: RH52PE404402.43 3 040 kB MSB: [00, 02] Speed: [100k, 333k, 6500k, 51k] Baud. Supported Hardwares: [0082, 1081] WD2 BT2 [WD2 ALGORITHM] MCU File: RH51_52_67_68PE404402.C1 24 045 kB MSB: [00, 02] Speed: [100k, 333k, 6500k, 51k] Baud. Supported Hardwares: [0082, 1081] TDCT4ReadInfoThread 2.7.8.2174 started at: 2009/08/24 09:06:26 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Initializing phone... Output power at Line1 3.99V is in range of: 4.00V ±10.0% Phone powered. Reading Info... MCU Version: V 7.0642.0 Date: 18-10-06 Type: RH-52 (7610) Additional_1: (c)NMP [Nokia 7610b CABLE 7610] PPM Version: V 7.0642.0 Date: 18-10-06 Type: RH-52 (7610) Pack: (c)NMP.43 Product code: 0514537 Production serial: PEN974429 Hardware version: 7033 Security code: 12345 Original IMEI: 354844-01-******** IMEI: 354844-01-******** Asic type: 5 Profile bits: 0000000000000005 Lockinfo: 0010100000000000 Lock version: 0 SIMLock service: SIMLOCKLIB VERSION 2.29 [04090004010C] -------------------------------------------------------------------------------- TDCT4ReadInfoThread 2.7.8.2174 finished at: 2009/08/24 09:06:48 Done. TDCT4ChangeModeThread 2.7.8.2174 started at: 2009/08/24 09:06:54 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Switching from Local to Normal mode... Reset mode set. -------------------------------------------------------------------------------- TDCT4ChangeModeThread 2.7.8.2174 finished at: 2009/08/24 09:07:10 Done. DCT4 PP File: euroals.pp 13 elements. WD2 BT2 [WD2 ALGORITHM] PPM File: RH51PE706420.32 2 127 kB Languages: English, Philipine (Philipines) MSB: [00, 02] Speed: [100k, 333k, 6500k, 51k] Baud. Supported Hardwares: [0082, 1081] WD2 BT2 [WD2 ALGORITHM] MCU File: RH51_52_67_68PE706420.C1 25 095 kB MSB: [00, 02] Speed: [100k, 333k, 6500k, 51k] Baud. Supported Hardwares: [0082, 1081] TDCT4FlashPhoneThread 2.7.8.2174 started at: 2009/08/24 09:09:01 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Input power: 15.38V OK. Hardware ID: 1081 Boot Loader: w3_2nd.fia 4 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] Max Flash Devices: 4 Flash ID 1: 00ECDDFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 00 SectorSize: 0x010000 Flash ID 2: 00ECEEFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 02 SectorSize: 0x010000 Flash ID 3: 00EC2250 - 0000 Rev: 0121 Manufacturer: Samsung MSB: 04 SectorSize: 0x010000 Flash ID 4: 00000001 - 0000 Rev: 0000 Manufacturer: Unused MSB: 06 SectorSize: 0x000001 Signature: C60000EA750100EA780100EA7B0100EA Flash Loader: w3_amd.fia 32 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] ASIC Type: 5 MSID: 84-80F9AB82FFD8D6EC3AD8AC5B CobbaID: 008D6F4D; 2984DA7E FAID: D2D5E50EB3DBDE29DD5D1790 Erase time: 3:10,6 sec. Flashing MCU file: RH51_52_67_68PE706420.C1 Flash time: 7:24,8 sec. After MCU Flash Delay: 5000 msec. Input power: 15.31V OK. Hardware ID: 1081 Boot Loader: w3_2nd.fia 4 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] Max Flash Devices: 4 Flash ID 1: 00ECDDFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 00 SectorSize: 0x010000 Flash ID 2: 00ECEEFE - 0000 Rev: 0121 Manufacturer: Samsung MSB: 02 SectorSize: 0x010000 Flash ID 3: 00EC2250 - 0000 Rev: 0121 Manufacturer: Samsung MSB: 04 SectorSize: 0x010000 Flash ID 4: 00000001 - 0000 Rev: 0000 Manufacturer: Unused MSB: 06 SectorSize: 0x000001 Signature: C60000EA750100EA780100EA7B0100EA Flash Loader: w3_amd.fia 32 kB Version: 4.76.0 Supported Hardwares: [1080, 1081] MSID: 84-80F9AB82FFD8D6EC3AD8AC5B CobbaID: 008D6F4D; 2984DA7E FAID: D2D5E50EB3DBDE29DD5D1790 Erase time: 16,2 sec. Flashing PPM file: RH51PE706420.32 Flash time: 33,2 sec. Total time: 12:10,8 sec. After Flash Delay: 15000 msec. Initializing phone... Output power at Line1 3.97V is in range of: 4.00V ±10.0% Phone powered. Set Defaults Timeout: 250 sec. Setting defaults (it can take a minunte, or more)... Set defaults time: 58,7 sec. Reading Info... MCU Version: V 7.0642.0 Date: 18-10-06 Type: RH-51 (7610) Additional_1: (c)NMP [Nokia 7610 CABLE 7610] PPM Version: V 7.0642.0 Date: 18-10-06 Type: RH-51 (7610) Pack: (c)NMP.32 Product code: 0514537 Production serial: PEN974429 Hardware version: 7033 Security code: 12345 Original IMEI: 354844-01-******** IMEI: 354844-01-******** Asic type: 5 Profile bits: 0000000000000005 Lockinfo: 0010100000000000 Lock version: 0 SIMLock service: SIMLOCKLIB VERSION 2.29 [04090004010C] Writing PP file... -------------------------------------------------------------------------------- TDCT4FlashPhoneThread 2.7.8.2174 finished at: 2009/08/24 09:22:54 Done. TDCT4ReadInfoThread 2.7.8.2174 started at: 2009/08/24 09:24:48 -------------------------------------------------------------------------------- MCU Nokia Version: 1.126, and up to date. SMCU Nokia Version: 1.44, and up to date. Reading Info... MCU Version: V 7.0642.0 Date: 18-10-06 Type: RH-51 (7610) Additional_1: (c)NMP [Nokia 7610 CABLE 7610] PPM Version: V 7.0642.0 Date: 18-10-06 Type: RH-51 (7610) Pack: (c)NMP.32 Product code: 0514537 Production serial: PEN974429 Hardware version: 7033 Security code: 12345 Original IMEI: 354844-01-******** IMEI: 354844-01-******** Asic type: 5 Profile bits: 0000000000000005 Lockinfo: 0010100000000000 Lock version: 0 SIMLock service: SIMLOCKLIB VERSION 2.29 [04090004010C] -------------------------------------------------------------------------------- TDCT4ReadInfoThread 2.7.8.2174 finished at: 2009/08/24 09:24:51 Done. |
i need nokia 3rd eddsion software Quick write with key | Master Software | Nokia Multimedia | 2 | 04-07-2010 18:04 |
m620 hung up succesfully okey | lilong_lee | NSPRO | 4 | 01-14-2010 17:16 |
j 700 hung up succesfully okey | lilong_lee | NSPRO | 0 | 09-07-2009 10:01 |
7610 hung up i try all virsion but stell same nokia afair in screen | lilong_lee | BB5KING | 16 | 08-24-2009 11:14 |
