Old 09-16-2010, 09:36   #1 (permalink)
saqi160's Avatar
Member: 780173
Sonork: 100.1594488
Thanks Meter: 912
nokia 1202 contact service
hi to all brothers
i have 1202 contact service
i sp lock it
Imei net: 3582850397****
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 0000000000000000
PROFILE_BITS: 0000000000030000
SIMLOCK_DATA corrupted!
Calculating SIMLOCK RPL using security server ...
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.2
[CR1]DCT4PLUS remaining credit: 36
Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-112_35828503971200_SIM.RPL"
Updating SIMLOCK ...OK
Reading Simlock info ...
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000003000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
but its same problem
i flash it 3.10 ver but problem same
i write imei and splock but problem not solve
this is its self test
Phone Type: RH-112
SW version: V 02.80 26-09-08 RH-112 (c) NMP
ID Test name Startup Result
46 UEM_CBUS_IF Y passed
15 SLEEP_X_LOOP Y passed
3 EAR_DATA_LOOP Y !failed !
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
39 WARRANTY Y passed
33 SIM_LOCK Y passed
10 PPM_VALIDITY Y passed
43 LCD Y passed
41 FLASH_CHECKSUM N passed
30 RF_CHIP_ID N !failed !
52 KASUMI N passed
plz help me its solution
The Following 2 Users Say Thank You to saqi160 For This Useful Post:
Old 09-16-2010, 09:47   #2 (permalink)
jaymercado48's Avatar
Member: 1382153
Sonork: 100.1594354
Thanks Meter: 60
unlock it with mx key
The Following User Says Thank You to jaymercado48 For This Useful Post:
Old 09-16-2010, 09:50   #3 (permalink)
Member: 1382153
Sonork: 100.1594354
Thanks Meter: 60
http://forum.gsmhosting.com/vbb/f550...2293-a-974636/
Old 09-16-2010, 10:03   #4 (permalink)
saqi160's Avatar
Member: 780173
Sonork: 100.1594488
Thanks Meter: 912
brother see my post i use mx key but not solve
Old 09-16-2010, 10:08   #5 (permalink)
mlife1999's Avatar
Member: 761005
Thanks Meter: 430
brother wash signal part and audio ,,,,,,then use mxkey hope problem solved
The Following 2 Users Say Thank You to mlife1999 For This Useful Post:
Old 09-16-2010, 11:27   #6 (permalink)
saqi160's Avatar
Member: 780173
Sonork: 100.1594488
Thanks Meter: 912
plz help me ,,,,,,,,,,,,,,,,,,
Old 09-16-2010, 12:52   #7 (permalink)
mojahiudul's Avatar
Member: 1393008
Sonork: C0821FB9
Thanks Meter: 47
may be its hardware problem
Old 09-16-2010, 12:57   #8 (permalink)
abdulrahimkhan's Avatar
Member: 442499
Sonork: 00737
Thanks Meter: 80
give full hwk info harryyyyyyyyyyyyyyyyyyyyy
Old 09-16-2010, 12:59   #9 (permalink)
Member: 442499
Sonork: 00737
Thanks Meter: 80
full ares and full flash =pm file=
sl repair
Old 09-16-2010, 13:00   #10 (permalink)
javedsf's Avatar
Member: 811013
Sonork: 03468717163
Thanks Meter: 744
unlock by InfinityBox 100 okkkkkkkkkkkkkkkkkk
Old 09-18-2010, 08:32   #11 (permalink)
saqi160's Avatar
Member: 780173
Sonork: 100.1594488
Thanks Meter: 912
thanks to all brothers
for replay
my problem is solve
i reheat cpu with pest
set working ok
thank s to all brothers
Old 10-03-2011, 18:32   #12 (permalink)
kiwewa's Avatar
Member: 1171295
Thanks Meter: 61
Bro use hwk, read nfo and then unlock your plobrem will solv
The Following User Says Thank You to kiwewa For This Useful Post:
Old 02-23-2012, 12:13   #13 (permalink)
Member: 784847
Thanks Meter: 45
hi brother
loo at his self test report care fully
43 LCD Y passed
52 KASUMI N passed
this is UEM fault
thanks
Old 06-05-2012, 07:55   #14 (permalink)
Member: 1238726
Thanks Meter: 2
goog work ..............
Old 06-05-2012, 10:38   #15 (permalink)
.::MAHABUB::.'s Avatar
Member: 939797
Sonork: 100.1601089
Thanks Meter: 359
Arrow
Originally Posted by gnmughal_786 View Post
hi brother
43 LCD Y passed
52 KASUMI N passed
this is UEM fault
thanks
yes i agree with you its UEM fault 100%.reboll or replace your problem will be solved.
Page generated in 0.29297 seconds with 9 queries
