Old 02-27-2014, 08:46   #1 (permalink)
Member: 971848
Thanks Meter: 29
Arrow nokia 305 restart
nokia asha 305 restart with sim but without sim phone will working well i flash phone by mxkey but same pls help me thanks in advance
here is mxkey flashing log
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: xxxxxxxx
Using device: USB ROM and HTI, FW ver: 00.50, SN: xxxxxxxx
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.117
Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013)
Processing MCU file: RM-750_111.021.0028_79u_prd.core.fpsx
[BB5,XSR 1.6] size: 118.70 MB
Supported Ids: 0003192103002007, 000C192103002007, 4003192103002007, 400C192103002007, 0003192103012007, 000C192103012007, 0003192103002107, 000C192103002107, 000C192103012107, 000C192103012107, 0003192103022107, 000C192103022107, 400C192103022107, 0003192103032108, 000C192103032108, 4003192103032108, 400C192103032108, 000C192103042108, 0003192103042108, 400C192103042108, 4003192103042108
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x]
CMT EM0 ID: 00001040
CMT EM1 ID: 00001060
CMT PUBLIC ID: BA670000FFFB3C40CF5813EC44103748CC6EF49D
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706
CMT ROM ID: 2CAC45E23BC33C8B
Loading CMT secondary boot code
SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 400C192103042108, 0003192103042108, 4003192103042108
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0050 - 0000 0232 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD45E0
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2517AB30
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x1CC bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35168005059884_CE RT.rpl"
CMT PAPUBKEYS HASH: F4C2F0A6BA76F178E59EBE710A8E1C85F3E122C0
Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK
Partitioning....
Partitioning complete
Erase size: 228.06 MB
CMT FLASH,MuxOneNAND area [00040000-0007FFFF]
CMT FLASH,MuxOneNAND area [000C0000-008BFFFF]
CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT SOS+DECOMP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: F4C2F0A6 [] sent
CMT GENIO_INIT block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 27.844 s
Processing PPM file: RM-750_111.021.0028_24.01_India_79u_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 34.39 MB
Erase size: 59.25 MB
CMT FLASH,MuxOneNAND area [09F40000-0DA7FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 8.860 s
Processing CNT file: RM-750_111.021.0028_U05.01_79u.uda.fpsx
[BB5,XSR 1.6] size: 154.73 MB
Erase size: 262.50 MB
CMT FLASH,MuxOneNAND area [0E980000-1EFFFFFF]
Programming completed in 37.172 s
Processing CNT file: RM-750_v0.017_APEONLY_prd.fpsx
[BB5,XSR 1.6] size: 3.87 MB
Erase size: 5 MB
CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF]
CMT SOS*ENO block sent
Programming completed in 1.328 s
Total time for flashing process(boot+erase+write) was 1 min 36.812 s
Waiting for device boot up ...
Device connected: nmwcdc\Nokia 500 USB Phonet, PORT_ID: BD05DA
Verifying communication to device OK.
Phone type: RM-750 (Nokia N00)
SW version: V 79u_sr1_12w20.1.2 30-07-12 RM-750 (c) Nokia
ApeCoreSw: 111.021.0028
Imei plain: 35168005059884-0
Product code: 059G7B8
Battery voltage: 3722 mV, current: 367 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 351680050598840
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 1.625 s
Page generated in 0.13806 seconds with 8 queries
